MUM Europe 2020
netmaster
filter out multicast
Mon Aug 29, 2011 11:51 pm
since there is no IGMP snooping, is there any way to prevent multicast frames getting out from some port with ACL rules. Tried to put 224.0.0.0/4 as IP Dst:, but no effect.
zervan
Re: filter out multicast
Tue Aug 30, 2011 8:52 am
Check appropriate "from" ports (incoming), fill "224.0.0.0/4" as "Ip Dst", check "Redirect To" and don't check any port there.
Dusan Zervan from Slovakia
MTCNA, MTCRE
winet
Wed Oct 12, 2011 4:39 pm
is it working? i'm going to buy SwOS if this works
zervan
Wed Oct 12, 2011 5:52 pm
I've tested that and it was working for me. It would be good if somebody else will confirm that too.
MTCNA, MTCRE
log
Thu Oct 13, 2011 4:04 pm
zervan - could you paste screen shot of your acl config?
zervan
Thu Oct 13, 2011 7:27 pm
Here you are:
MTCNA, MTCRE
log
Wed Oct 19, 2011 10:56 am
Here you are:
Ok but I dont understand one thing. IGMP Snooping "knows" from which port to which port multicast is going. So what gives you that configuration?
netmaster
Wed Oct 19, 2011 11:29 am
look into this like manual IGMP snooping. With this setup you can filter out multicast from some ports or all of them.
in configuration, mentioned above is:
IP Dst: 224.0.0.0/4 (this selects all packets with multicast destination IP's)
Redirect To: none (previously selected packets is not forwarded to any ports)
or if you select some ports in "redirect to", then multicast will be forwarded to these ports only. After all, it is the same thing what IGMP snooping does, but it does it automatically when group joining and leaving messages pass the switch.
And I can confirm, this config works really well.
punik
Tue Oct 25, 2016 10:41 am
how to implement this in routeros?
stormeporm
Wed Jan 25, 2017 6:23 pm
Guess like this cant test it.
/interface ethernet switch rule add ports=ether1 switch=switch1 dst-address=224.0.0.0/4 new-dst-ports=
You should check your switch en and port nr.
Let met know if it works.
lpt2007
Fri Nov 30, 2018 12:18 am
Where I find this in winbox?
Users browsing this forum: No registered users and 5 guests
