MUM Europe 2020
endre
SwOS 1.6 vs CollectD: SnmpGetNext fail
Thu Jun 21, 2012 8:26 pm
CollectD - a monitoring tool - uses SnmpGetNext request to fetch various interface counters. This does not work with RB250G running SwOS 1.6, as it replies back with a malformed packget when CollectD tries to request data for the non-existent Port6:
2012-06-21T17:13:52+00:00 localhost daemon info collectd[5022]: snmp plugin: host 44.128.156.98: snmp_sess_synch_response successful.
2012-06-21T17:13:53+00:00 localhost daemon err collectd[5022]: snmp plugin: host 44.128.156.98: snmp_sess_synch_response failed: Timeout (parse header: message overflow: 75 len + 2 delta > 61 len)
tcpdump output shows that:
17:11:32.483825 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 105)
    44.128.156.1.47970 > 44.128.156.98.161: [bad udp cksum 0x91ca -> 0xe003!]  { SNMPv1 { GetNextRequest(62) R=2055248100  .1.3.6.1.2.1.2.2.1.14.5 .1.3.6.1.2.1.2.2.1.20.5 .1.3.6.1.2.1.2.2.1.2.5 } }
17:11:32.485484 IP (tos 0x0, ttl 254, id 39635, offset 0, flags [none], proto UDP (17), length 89)
    44.128.156.98.161 > 44.128.156.1.47970: [udp sum ok]  [len59<asnlen75]
And yes, I can reproduce it manually:
With physical port 5:
# PORT=4
# snmpgetnext -v 1 -c public 44.128.156.98 .1.3.6.1.2.1.2.2.1.14.${PORT} .1.3.6.1.2.1.2.2.1.20.${PORT} .1.3.6.1.2.1.2.2.1.2.${PORT}
17:06:35.976060 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 105)
    44.128.156.1.47831 > 44.128.156.98.161: [bad udp cksum 0x91ca -> 0x47ad!]  { SNMPv1 { GetNextRequest(62) R=1071494435  .1.3.6.1.2.1.2.2.1.14.4 .1.3.6.1.2.1.2.2.1.20.4 .1.3.6.1.2.1.2.2.1.2.4 } }
17:06:35.977886 IP (tos 0x0, ttl 254, id 15059, offset 0, flags [none], proto UDP (17), length 112)
    44.128.156.98.161 > 44.128.156.1.47831: [udp sum ok]  { SNMPv1 { GetResponse(69) R=1071494435  .1.3.6.1.2.1.2.2.1.14.5=0 .1.3.6.1.2.1.2.2.1.20.5=0 .1.3.6.1.2.1.2.2.1.2.5="Port5" } }
IF-MIB::ifInErrors.5 = Counter32: 0
IF-MIB::ifOutErrors.5 = Counter32: 0
IF-MIB::ifDescr.5 = STRING: Port5
Trying to get the next OID in tree, refering non-existing to physical port 6:
# PORT=5
17:06:39.548947 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 105)
    44.128.156.1.43823 > 44.128.156.98.161: [bad udp cksum 0x91ca -> 0x9249!]  { SNMPv1 { GetNextRequest(62) R=26214195  .1.3.6.1.2.1.2.2.1.14.5 .1.3.6.1.2.1.2.2.1.20.5 .1.3.6.1.2.1.2.2.1.2.5 } }
17:06:39.550805 IP (tos 0x0, ttl 254, id 15315, offset 0, flags [none], proto UDP (17), length 89)
    44.128.156.98.161 > 44.128.156.1.43823: [udp sum ok]  [len59<asnlen75]
Timeout: No Response from 44.128.156.98.
It sould response with the next OID in the tree or with a message when the request has ended the tree, like:
    44.128.156.98.161 > 44.128.156.1.52598: [udp sum ok]  { SNMPv1 { GetResponse(30) R=1971931419  noSuchName@1 .1.3.6.1.2.1.2.2.1.20.5= } }
Please FIX it.
0pl0pl
Re: SwOS 1.6 vs CollectD: SnmpGetNext fail
Sun Mar 03, 2013 10:56 pm
Same bug with cacti.
Solution:
"Older SNMP devices need the max oid's of the device reduced to as little as 1 to work. "
http://forums.cacti.net/viewtopic.php?f=21&t=37258
rcmcronny
Mon Mar 04, 2013 12:28 am
no, you simply have to set the "Maximum OID's Per Get Request" in Cacti accordingly. I have no issues with the default (10) and my RB250GS.
Try to change this setting to "1" and check how it goes.
But yes, this is definitly a bug. (already in my list included :) ).
Ronny
Users browsing this forum: No registered users and 2 guests
