becs
SwOS version 1.13 released
Wed Jun 18, 2014 2:33 pm
What's new in 1.13:
*) allow to disable SFP port;
*) do not disable SFP port if loss of signal is detected, some SFP modules
do not report it correctly;
*) make autonegotiation work better;
What's new in 1.12:
*) fixed problem - SFP port stops after ethernet port cfg change (RB260 only);
*) change default vlan mode on RB260 to 'optional';
*) fixed problem - SNMP worked even when disabled;
*) fixed problem - SFP autonegotiation setting was not saved (RB260 only);
*) fixed uptime to be correct;
*) fixed RB260GSP poe-out to work correctly after downgrade & upgrade back;
What's new in 1.11:
*) added support for RB260GSP;
What's new in 1.10:
*) allow to disable/enable auto negotiation on SFP port on RB260;
*) fixed problem - hosts tab stopped working if 0:0:0:0:0:0 was learned on RB250;
*) enable transmit on SFP port only when module with signal is detected;
*) fixed problem - port lock & lock on first did not work on RB260;
*) fixed problem - port full duplex setting was set for wrong port on RB260;
*) fixed problem - broadcast correct uptime to it's neighbors;
*) fixed problem - port egress rate did not limit traffic properly on RB260;
*) fixed problem - sometimes board did not reboot after upgrade;
*) added vlan-id to static host table;
http://www.mikrotik.com/download
This version fixes 1Gbit ethernet autonegotiation with Cisco 3550 and improves compatibility with SFP modules which do not have DDM.
mpreissner
Re: SwOS version 1.13 released
Wed Jun 25, 2014 2:09 pm
Any plans to add RADIUS authentication instead of local username/password?
Michael Preissner
CISSP, CCSP, CEH, PMP
docmarius
Tue Jul 08, 2014 1:32 pm
Please update the wiki so the SwOS manual covers the PoE options in the "Link Tab" section for the RB260GSP.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
LynxChaus
Tue Jul 08, 2014 2:32 pm
This version break SFP link status reporting over SNMP. Module present, loss of signal detected but SNMP reports IF-MIB::ifOperStatus.6 = up(1).
honzam
Mon Sep 08, 2014 10:27 pm
Mikrotik : Why no topic about 1.14?
No info about new version on email.
LAN, FTTx, Wireless. ISP operator
TBK
Thu Oct 09, 2014 12:49 am
What's new in 1.14:
*) fixed RB260GSP poe-out;
Source: http://download.mikrotik.com/swos/changelog.txt
For 1.15 it would be great if an option to disables the LEDs permanently or partially (in accordance with a timetable) was added.
raflik
Fri Oct 17, 2014 12:26 pm
What's new in 1.14:
and allow to change port name and add vlan name. Maybe add some log with information port down/up - date/time?
honzam
Fri Oct 17, 2014 8:16 pm
What's new in 1.14:
+1
pepino
Wed Oct 22, 2014 12:01 pm
What's new in 1.14:
...and serial number and firmware version available over snmp.
Users browsing this forum: lullerhaus and 7 guests
