cityboy
Re: RouterOS v7.0 beta1 - when?
Tue Aug 16, 2016 2:49 pm
I bought an MC7355 6+ months ago to use as a cell modem. Your page claims it will be in v7, but that still hasn't come out yet. When can I expect to be able to use it? It doesn't even show up in the USB list, let alone the "/interface lte" menu.
Thanks.
I bought MC7304 and I have the same problem
maxluq1990
Sat Aug 20, 2016 1:50 am
Hi, guys!
I'm Max from Argentina and new in this forum.
I bought one month ago (like other members) a Sierra Wireless AirPrime MC7355 4G Mini PCI-E card for my basebox 5 and I thought that the OS 7 is already released because I read on the "Hardware Compatibility" page that the MC73xx is compatible with that version. My surprise was when I noticed that the os7 is not released yet and neither there are an RC or beta version :(.
I seen that We are several users waiting for the arriving of the new version.
Thanks by the space for our expression and questions.
Greetings!
Max!
RogerWilco
Fri Aug 26, 2016 2:32 am
Thanks.
The MC7304 DOES work now with PPP.
cityboy
Fri Aug 26, 2016 4:01 pm
I know but I'm waiting for lte
pe1chl
Fri Aug 26, 2016 4:04 pm
I would prefer PPP on my Huawei sticks because LTE introduces yet another layer of NAT.
Siona
Sun Aug 28, 2016 12:47 am
But using ppp is slowing you to 20-30mbps
pe1chl
Sun Aug 28, 2016 12:19 pm
I have no problem with that. Realistically the speed is not much more than that anyway.
Remember the advertised speed is the aggregate speed for all users on that access point.
Siona
Sun Aug 28, 2016 12:33 pm
Sure but there are some places in Poland you can get 75 Mbps easly.
pe1chl
Sun Aug 28, 2016 5:52 pm
I would still prefer not having NAT. Unfortunately on the Huawei E3372 sticks that I use it is very difficult to switch between LTE and PPP, otherwise I would do it.
I don't see why the stick has to have NAT to use the LTE interface. In earlier 2G and 3G sticks there were similar interfaces and they worked
just like an ethernet interface with DHCP. Should be possible with LTE as well.
(note this is not a MikroTik gripe, the problem is in the "Hilink" firmware of the Huawei stick)
Siona
Sun Aug 28, 2016 5:56 pm
Best one would be an e3372 with bridge mode possible ... but there isn't.
smurphy
Fri Sep 16, 2016 10:35 am
We will release a beta, when it will exist. Currently v7 is in alpha stage, many functions are not completed and non functional. Beta needs at least all functions to be somewhat operational.
Right.
Any chance to get (even in early Alpha) one minimal V7 release, just to test the installation/booting capabilities on a j1900 Atom board? (x86).
It has taken me a while to figure out a way to install 6.x on it, as the USB gets disconnected as soon as the kernel drivers take over.
At least, if you provide me access to your currently used kernel source code so I can compile it and run it on that beast (Probably with an alpine OS base).
I really just want to make sure that when it is release it will run on that hardware of mine :}
Thx.
nz_monkey
Fri Sep 16, 2016 11:00 am
Thx.
RouterOS v7 will use a 4.4 or newer kernel as a base. If 4.4 or newer boots on J1900 than chances are RouterOS v7 will boot and work.
pe1chl
Fri Sep 16, 2016 11:10 am
Of course it does not only depend on the kernel version number but also on the kernel configuration options used
at compile time. We cannot know what drivers MikroTik include in the compile, we only know that it is not all of them.
smurphy
Fri Sep 16, 2016 11:28 am
Thx.
This I know. I have This device: http://hamsing.com/product/html/?39.html - and managed to install routerOS 6.36.3 on it. Only I have no usage of any USB ports after the kernel takes over.
The network interfaces works though. And because that box has no Serial-Port, I have no console access at all to it.
I managed to also run this system very fine using a 3.16.0 / Debian Jessie 8.5 and had no problems at all. Even installing from CDRom worked fine (Using UEFI device).
On the other hand, I am unable to install any RedHat/CentOS 5.x or 6.x system, as the USB gets disconnected as soon as the kernel takes over, disconnecting the CDRom drive and preventing the installer to load additional data. ClearOS also fails (even though I tried Legacy and UEFI boot methods). Didn't try CentOS/RedHat 7 yet... Will try Ubuntu Server 16.04 LTS next.
Most of the time where the installation works, is when I do it using netinstall (after initial system and ramfilesystem are loaded, the rest is done over network), or when using UEFI boot mode (Even if I also have seen it fail). Netinstall does not require USB, while with UEFI sometimes, the USB still works after kernel takes over.
smurphy
Fri Sep 16, 2016 11:29 am
This is why I asked for the kernel source and configuration file. That way, I could test and make a running kernel (eventually also identifying what went wrong - if it went wrong ;) ).
nz_monkey
Fri Sep 16, 2016 1:02 pm
Maybe wait until v7 beta is out, and if there are any issues with your specific hardware you can work with support to get the relevant drivers added at that point.
smurphy
Fri Sep 16, 2016 2:26 pm
This - I will definitely do :) Hopefully it comes out before I get my Fiber connection :D
nadeu
Fri Sep 16, 2016 5:34 pm
You keep thinking that the version 7 is published?
smurphy
Sat Sep 17, 2016 1:11 pm
No. When it comes out.
okoun
Fri Dec 02, 2016 12:43 am
Now it is December 1 and version 7 beta is not even a comma ... Does not Mikrotik? :(
It looks like the end of the world?
Chupaka
Fri Dec 02, 2016 3:17 am
What's wrong with December 1? :)
normis
Fri Dec 02, 2016 11:24 am
Maybe next summer. I don't think anyone promised December 1st :)
patrick7
Fri Dec 02, 2016 11:29 am
Not 1st of december, but 2016... See ticket 2016010866000027.
Waiting would be much easier if mikrotik would provide additional information about v7 (screenshots, a list with fixed bugs, roadmap, any status update about the progress, etc...).
At the moment the only thing MikroTik tells us is "it's done when it's done". And that for more than 3 years, with serious bugs in v6 which MikroTik refuses to fix because "it is fixed in v7".
normis
Fri Dec 02, 2016 11:33 am
Your ticket.
Question from you: "Will it still be end of the year? :)"
Support answer: "I cannot tell you when exactly. It's ready when it's ready."
You ask again, later: "I didn't ask for an exact date."
Support answer again: "There are delays so It is not even known when first beta will come out."
patrick7
Fri Dec 02, 2016 11:55 am
Not true.
It definitely will be released this year. Unfortunately I do not have specific date.
-> That was the promise.
Some time later I asked if this promise still is valid and then you said no.
Don't get me wrong, I don't expect you to release it tommorrow, but some additional informations (and bugfixes in v6, like recursive routing, BGP peers dropping when you show advertisements) would be appreciated.
It looks like you already started to fix v6 - see the 0:0 bug. Thanks for that.
normis
Fri Dec 02, 2016 12:03 pm
Manipulating a support desk agent into giving such an answer can't speed up programmers with their work :) Sorry about that.
It will be ready when finished.
patrick7
Fri Dec 02, 2016 12:11 pm
I didn't manipulate anyone. And as said, I don't expect you to be faster. But maybe to change the information strategy, and don't say "we don't fix v6 because v7 will do".
normis
Fri Dec 02, 2016 12:15 pm
You are twisting my answers. The issues can't be fixed because of limitations in v6 kernel. Not because we don't want to, or because v7 is coming soon.
patrick7
Fri Dec 02, 2016 12:23 pm
Accepted. But it isn't possible to make some workaround? As an example, limit print commands to 25% cpu?
Chupaka
Fri Dec 02, 2016 1:20 pm
normis
Fri Dec 02, 2016 1:21 pm
Barely spring, not summer in Latvia yet.
okoun
Fri Dec 02, 2016 5:57 pm
The energy that is spent on these MUMs would be better to move the development RouterOS 7
MUM same thing all the time but this has probably nobody cares much ...
patrick7
Fri Dec 02, 2016 7:28 pm
@MikroTik Feature request which should not depend on kernel version: delete / match bgp communities by regex. Asked a lot here in the forum, and it would make many setup's much better.
AndreaTIK
Fri Dec 02, 2016 9:53 pm
Your ticket.
To be fair, in the company I work for, a support rep daring answer a customer "it is ready when it is ready" would experience an unpleasant moment.
And, I am not particularly waiting for v7, but this thread, and the similar ones, are starting to become offensive to customers.
I understand that you may be joking, but I don't particularly like answers I consider the official Mikrotik voice when coming from an employee similar to
When it is summer, when it is spring... not yet summer in Latvia... not there yet... maybe in some time...
Please, do as you say.
If you cannot provide a roadmap, or further info, "sorry but we cannot comment on this" would be in my opinion a way better answer than continuous postponing. Especially if you do this for years.
Edit: typos and grammar
Tonda
Sat Dec 03, 2016 9:37 am
I fully agree with AndreaTIK. Normis, please do not play with customer's patience. For me personally delays with RouterOS v7 means, that I will not buy another bunch (around 50) of Mikrotiks, because I have to use 3G dongles with promised support in RouterOS v7, so I currently have to evaluate another solutions. Of course, you can tell yourself, what is bunch of 50 Mikrotiks for us when we sell them by millions, but I am sure, that there are lot of similar stories all around the world.
And in fact it is harm not for us, your customers, but for you - Mikrotik.
Milan
Sun Dec 04, 2016 9:11 pm
Just a small advice: if you need NAT on IPv6 you are doing something wrong...
Masquarade is dynamic NAT, which is not needed in IPv6. Static NAT (1:1) is another question and it's non-presence is a showstopper in many situation. Inability to make a hot fix for IPv6 addressing means you are unable to do/fix a lot of critical (ie not-planned) situation... I have to avoid IPv6 until proper NAT is available or I have to make special IPv6 subnet for every server I have (in a shared segment).
kopimi
Tue Dec 06, 2016 2:14 am
long time mikrotik user here, first time poster.
I am guessing that 95% of the people in here waiting for v7 are patiently awaiting the multi-core features, especially (for me) the BGP part. I have lots of cisco equipment that is junk compared to the mikrotik but still the only thing I can use because the multi-core is non-existant in v6. I don't care about the v7 beta, I just care about being able to get full usage of the current hardware we run.
If the v7 is taking so enormous amounts of time, and we know how much better v7 is (I've talked to lots of people at mikrotik about this, I've been at the meetups etc, seen the stats in the slides) - why can't you just release the bgp parts? Is this also a kernel limitation?
I rarely have issues with people joking but agree that the tone from the support is just annoying now. Don't joke about things when people are upset and annoyed. Timing is what's needed. And don't have bad timing when people are tired of spending time waiting...
normis
Tue Dec 06, 2016 8:50 am
One of the reasons v7 takes so long, is that routing programs are being completely re-made from scratch. There is nothing yet to backport.
nz_monkey
Tue Dec 06, 2016 10:03 am
For some reason I think of this:
okoun
Tue Dec 06, 2016 11:11 am
I understand.
So please leave a development version 6 and let everyone FULLY engaged only version 7 and will be out soon ..
ErfanDL
Tue Dec 06, 2016 2:02 pm
releasing V 7.0 stable for christmas :D
normis
Tue Dec 06, 2016 2:04 pm
Yeah, but which year?
Chupaka
Tue Dec 06, 2016 2:21 pm
17th
2117th...
normis
Tue Dec 06, 2016 2:28 pm
ErfanDL
Re: RE: Re: RouterOS v7.0 beta1 - when?
Tue Dec 06, 2016 3:01 pm
17th
2117th...
:D :D :D
ErfanDL
Tue Dec 06, 2016 3:02 pm
Maybe century 22 :D
cheeze
Tue Dec 06, 2016 7:42 pm
Yeah I can totally understand that. Conforming to RFCs and programming a routing stack is *NOT* easy. I'm sure it's one of those things where the programmers sat down and said that it would just be better to redo it from scratch. Which I believe is fine. If the current routing stack is not flexible enough then I think we completely understand that. However I'm kinda looking at it from the business perspective as well. Would it be worth getting something like IP Infusion's ZebOS and integrate that into RouterOS as the routing stack and letting the programmers focus on non-routing stack related features? The reason why I say that is because a routing stack is something that is just a *very* high amount of work that will consistently keep on requiring more and more work (as more and more RFCs come out requiring a routing protocol to do this or that). It sounds like Mikrotik has said that they want to put in that amount of work into developing their own. That's fine and all, however I think adding some small routing features to the current RouterOS is needed just to keep RouterOS moving forward. Reason why I say that is because other vendors are adding more and more features faster (because they have more engineers) and if Mikrotik is to keep up then Mikrotik will have to make a compromise on where to add development time. Now I am not suggesting that Mikrotik scrap the work they have done. I'm sure that the routing stack is probably about 40-50% completed. I'm sure that by about April/May it'll be "feature" complete and probably summer it'll be released as "Beta" for us to test out and around September to October ROS 7 will likely be released. That is fine, but in the mean time we as customers are literally begging for some features that can be put into ROS 6 that aren't big. The one thing that I've been chomping at the bit for is IPv6 BGP next hop resolution. All of the other IPv6 stuff I think can wait, but man that one right there is paramount for making IPv6 "work" on RouterOS. Not being able to get that to work is really a killer. Even if Mikrotik says no, and says that it's not worth investing into the current RouterOS routing stack, then that's fine. I also know that people have requested for a roadmap. Not a development roadmap, but more of a "this is kind of what we are looking to get into ROS 7 on first release" roadmap. Is ISIS going to be added? Is BGP (and other routing protocols) going to be multithreaded (we have the answer to this one....but just using as an example)? Will we be given an ability to be able to tweak convergence time in the routing protocols (like SPF algorithm controls in OSPF, protocol independent convergence for BGP)?
It's more of a transparency thing that's all. We as customers generally like Mikrotik and I think we all generally want to see the equipment get better and better. I know I personally do. I know that Mikrotik can't reveal too much about the state they are in with what they develop because of business agility and keeping other competitors on their toes (like UBNT), but there has to be some give and take with customers....especially since we are waiting and building our networks around Mikrotiks' releases. How about this, on the next big MUM that happens (like the biggest MUM of the year) is it possible for Mikrotik to give a roadmap of what they would like to get into ROS 7.0 release? Just as an olive branch for us customers so we can know how to plan our networks out in the mean time?
For what it's worth that's I guess my feeling on the situation. I'm sure most other people would probably agree and others won't but I figure being honest isn't bad...
pietroscherer
Trainer
Trainer
Tue Dec 06, 2016 8:15 pm
I received in my whatsapp :lol:
cheeze
Tue Dec 06, 2016 8:47 pm
Ok so that's just hilarious.
blingblouw
Tue Dec 06, 2016 8:50 pm
Got me too...dang
AndreaTIK
Wed Dec 07, 2016 6:20 pm
Coding is hard.
Project management is hard.
But this is your job.
Excusatio non petita, accusatio manifesta
Second time, please, stop making fun of us.
Maybe it is just me, but I feel It is disrespectful coming from an employee to a customer.
This tends to backfire, in spectacular ways.
cheeze
Wed Dec 07, 2016 8:43 pm
Coding is hard.
I think you're being a little...harsh here. The reason why I say that is because generally the people on these boards are NOT the people whom make the decisions at Mikrotik. So giving the support people grief will only generally cause for nothing to get done. It might even be a detriment honestly.
That being said, I agree that it's very frustrating on the end of the customer. However the "best" general way to do things is to just push consistently. If more people pushed consistently then there would be more pressure upon the management to do something different. However we need to be nice to the people we interface with.
As always, that's why I send emails, support tickets, and generally keep on bothering them in a nice way.
jenechka
Sat Dec 10, 2016 5:21 pm
are there any plans in version 7 fix problems with iptv ??
Chupaka
Sat Dec 10, 2016 7:25 pm
what problems?
jenechka
Sat Dec 10, 2016 7:43 pm
Chupaka
Sat Dec 10, 2016 7:49 pm
Feature request is not a problem :)
So just wait for the release
jenechka
Sat Dec 10, 2016 7:56 pm
no, not request
igmp snooping very need)
mirhav
Thu Dec 15, 2016 11:52 am
v7 ?
I think it will be a Christmas gift :-D
Mirek
mikruser
Long time Member
Long time Member
Thu Dec 15, 2016 1:06 pm
v7 ?
I expect v7 immediately after Christ Second Coming
Chupaka
Thu Dec 15, 2016 1:35 pm
I'm more optimistic. Immediately BEFORE :)
pe1chl
Thu Dec 15, 2016 2:21 pm
But what year?
jenechka
Thu Dec 15, 2016 5:21 pm
RouterOS v6: may 2013 — present (based on Linux kernel 3.3.5)
RouterOS v5: March 2011 — September 2013 (based on Linux kernel 2.6.35)
RouterOS v4: October 2009 — March 2011 (based on Linux kernel 2.6.26)
RouterOS v3: January 2008 — October 2009 (based on Linux kernel 2.4.31)
delay)))
ErfanDL
Thu Dec 15, 2016 7:37 pm
But what year?
Century 22 :D
honzam
Thu Dec 15, 2016 10:38 pm
Thanks for the info. V6 is there over 3 years :shock:
It seems that Mikrotik have a "tiny" delay
cheeze
Thu Dec 15, 2016 10:48 pm
What version of Linux is ROS 7 supposed to be built on.....is it in version 4?
nz_monkey
Fri Dec 16, 2016 11:11 am
It is 4.x Kernel. We won't know exactly which one until it is released.
Mikrotik need to find a Kernel that can be patched for all their different architectures and that has the features they need. Not an easy task I am sure !
Netsplite
Sun Dec 18, 2016 2:47 pm
Rewriting mayor parts from scratch while still maintaining stable releases takes time, RouterOS is not something small anymore with plenty of hardware to support and it doesn't have the same amount of resources like the mayor ones (Cisco / Juniper).
So think it's a bit unfair by some to demand an early release especially since we have a perfectly fine release right now (6.x) which gets regular updates with new features and bug fixes, pretty sure Mikrotik shifts priorities to the important areas right now and we will see ROS 7.0 beta at best early next year after they launched a new line-up.
pe1chl
Sun Dec 18, 2016 3:01 pm
That is why it is not a good idea to rewrite all major parts from scratch for a new revision.
As you can see, new functions and extra capabilities for existing functions are introduced in 6.x all the time.
To rewrite the routing, a sensible approach would be to have new routing code in a new optional package (as was done with wireless)
and keep the old package for the normal user until the new package is stable.
Chupaka
Sun Dec 18, 2016 10:44 pm
new routing requires new kernel. a new optional package with a new kernel (and all the other 'optional packages' compatible with that kernel) is just a new version of RouterOS :)
docmarius
Mon Dec 19, 2016 8:35 am
I would rather see another approach:
The release of a 7 beta with the new kernel (let's say 4.4 - the latest LTS) together with the exiting current packages, which should be not such a big fuss, since kernel networking is generally backwards compatible at API level. This would actually test kernel stability in various scenarios.
Afterwards, a progressive rollout of new features is possible, making use of the new features (which are really interesting - e.g. VRF, multipath routing, per flow routing, KVM).
nz_monkey
Mon Dec 19, 2016 9:23 am
The problem is getting all the kernel patches from each chipset vendor working optimally on that kernel. E.g. they need a Kernel that can take Qualcomm MIPS, MediaTek MIPS, Qualcomm ARM, Freescale PPC and Tilera patches. No easy feat!
I'm sure this is made even harder by Tilera being acquired by EZ Chip and then EZ Chip by Mellanox, I can't imagine SDK support on the Tile GX is that fantastic for newer Kernels :(
Then on top of that you have the VRF and network namespaces changes around Kernel 3.16
So I don't think it's as easy as just running v6 routing on a 4.4 Kernel. There are too many other parts that need to work, and the way VRF's work is fundamentally different.
pe1chl
Mon Dec 19, 2016 11:18 am
What I mean is they should have released a new version with a new kernel without combining that effort with a rewrite of all the routing, and then do that rewrite independently in an optional package just like the wireless.
The old routing code can run on the new kernel without much effort, at least it can on all the major Linux distributions.
Combining so many rewrites in a single new release means it will never get done.
pe1chl
Mon Dec 19, 2016 11:19 am
That is exactly what I had in mind.
paoloaga
Tue Dec 20, 2016 12:34 am
Look at Tesla. They rolled out hardware autopilot 2.0. The first shipped units have no features enabled, there aren't even basic ones like cruise control. Features will be added with software updates.
Maybe it could be possible to follow the same path using RouterOS V7: Released featureless in parallel with V6, with features added over time allowing the community to test it.
In many use cases it will be good because not every router make use of ALL the features at the same time.
My 0.02 bitcoins.
pe1chl
Tue Dec 20, 2016 1:03 pm
Yes, I think it is much better. An all-rewritten RouterOS 7 will have so many little bugs scattered all over the place that nobody
will be able to use it at the very early stages. There is always some showstopping bug that makes it impossible to roll it
out on a nontrivial network. Hence it will not be field tested well and when it comes out of beta, there will be an enormous flood
of bugreports and frustration.
When instead the new version 7 will just be a move to a new kernel with the absolutely required changes in all the software
around it, subsequently every part that they always wanted to improve can be done and tested by those who require that
functionality, while all the others are just running the code and find the minor bugs, just as is happening now with v6 and has
happened with the wireless-fp and wireless-rep packages. Even there you could see that some people only moved to the new
package when the old one was discontinued and only THEN they found it did not work in their environment. With a monolithic
v7 release that would happen for many functions at the same time.
StubArea51
Trainer
Trainer
Mon Dec 26, 2016 4:45 pm
I would like to go ahead and put RouterOS v7 on my Christmas list for 2017 :-)
jrpaz
Fri Jan 13, 2017 2:34 pm
I would like to go ahead and put RouterOS v7 on my Christmas list for 2018.
hknet
Sat Jan 14, 2017 12:11 am
as we won't get ROSv7 anytime soon, anyone with knowledge how to crosscompile for the CCR platform and build a system to run quagga or similar?
Chupaka
Sat Jan 14, 2017 2:24 am
maybe, something like http://www.mellanox.com/repository/solutions/tile-scm/ ?
uid99
Wed Jan 18, 2017 1:24 am
I would just like to add my voice to several others here. I really like Mikrotik, and thankfully I'm not running into all of the problems recounted here, as my implementation is more localized and isn't leveraging BGP. However, it was frustrating after buying the device to discover just how dated the OpenVPN implementation was, and its completely lack of support not only for UDP but certificate based TLS authentication.
Maybe there's something in the core implementation that blocks this, but my *guess* is that it's (at best) a slightly customized version of OpenVPN. The kernel interfaces haven't changed AFAICT, so why in the world a more current support for secure SSL VPNs can't be provided is beyond me. It's great to see improved IPSEC in the latest releases, but it only underscores for me the frustration in not having this implemented, and not having any kind of idea of when it might be.
patrick7
Wed Jan 18, 2017 1:33 am
Or maybe it's a complete rewrite of OpenVPN? (licence issues?)
nz_monkey
Wed Jan 18, 2017 9:10 am
I have heard from a few sources that the OpenVPN code base is a nightmare to work on.
janisk
Wed Jan 18, 2017 10:00 am
OVPN tunnel has no common code with open source implementation of the said tunnel type.
PtDragon
Thu Jan 19, 2017 10:02 pm
Dear support and developers, could you please spend 10-15 min a month to post progress summaries for V7?
I'm not asking for huge detailed report, just very quick summary so we can see some progress going.
cheeze
Thu Jan 19, 2017 11:39 pm
This is a great freaking idea actually.
Kinda give like an outline of, "hey this is what we're working on now."
I think it would help a lot of us understand kind of the view of how Mikrotik is approaching what they are doing.
honzam
Thu Jan 19, 2017 11:56 pm
+ 1
JimmyNyholm
Wed Jan 25, 2017 3:14 pm
+1 Summarized status updates at given intervall is considered good Customer Relations.
Vitis
Thu Jan 26, 2017 12:18 pm
Hello Normis,
I would like to know, when we can expect, that the ROS version 7 will be out.
There are so many things that you promise to solve in v7 and we are waiting too long.
Those are your words from 2015
Not yet, but v7beta is coming later this year
http://forum.mikrotik.com/viewtopic.php?t=70274#p490716
dlynes
Thu Feb 02, 2017 5:56 am
Easy solution - do not make any expectations :)
We have already posted from time to time, that the biggest change is under the hood (minor kernel upgrade). There is no new GUI or anything. We are also working on a new routing engine.
Actually we are making really cool stuff even in v6. Look at the recent RC versions - interface lists, domain lists for firewall, repeater mode etc.
Minor kernel upgrade? I heard RouterOS 7 is based on FreeBSD, whereas all previous versions were based on Linux?
shahbazian
Trainer
Trainer
Thu Feb 02, 2017 2:05 pm
+1
mhugo
Mon Feb 06, 2017 5:13 pm
New routing engine is a big expectation together with multicore bgp. That would be great :)
/Mikael
sailor082
Mon Feb 06, 2017 8:50 pm
Exactly 2 ( two) years ago your info was that V7 is in alpha stage. Any progress? At least for a beta release....
We are all looking forward .Maybe some new info will be apriciated by all from your side.
Regards
patrick7
Mon Feb 06, 2017 9:50 pm
I don't think there will be news soon. A few weeks ago MikroTik wrote something about VRF/Linux Network Namespaces. They mentioned that network namespaces "may" be used. VRF is something very fundamental. Many things are depending on that (Firewall, MPLS, BGP, ...). It looks like not even MikroTik knows what will be implemented in v7.
I personally started switching to SuperMicro 5018D-FN8T (2x 10Gig, 6x Gig) with Debian and bird. The routing "just works", no performance issues, bgp multicore, Large BGP Communities support, BGP Additional Path support, conntrackd, working OpenVPN, much more ....
nz_monkey
Tue Feb 07, 2017 9:08 am
Where did they write this ?
patrick7
Tue Feb 07, 2017 11:15 am
sailor082
Wed Feb 08, 2017 8:33 am
I see.
I had some hopes when I knew that MIkrotik have a good support , taking action on costumers request's but unfurtunately I was wrong. As long anyone knew the long list of request and expectation from V7 and not even a small good will we can't see .....I don't know.If will keep the good work as was by now is very probably to have in 2 years first beta, if we are lucky, and some of us will notice ( hope not) that the hardware we own will not be in minimum requirment list !!!
Give us a hope Mikrotik as we trust on you when we pass to use your hardware. :(
Regards
guilhermeramires
Trainer
Trainer
Fri Feb 17, 2017 4:05 pm
But does it support multi thread? Last time I read quaggas docs it says that quagga is planned to support but so does not have the right libs for that...
hknet
Wed Feb 22, 2017 3:38 am
True, but at the moment on BGP and IPv6 I'd settle for anything that works without having to set static ipv6 routes to other BGP speakers loopback IPv6 addresses...
jenechka
Mon Feb 27, 2017 5:11 am
just in case let me remind you, it is waiting for full support multicast and IPTV in 7 versions :wink:
rxmd
Thu Mar 02, 2017 10:28 am
+1 - that would be very nice, just to have the feeling that you are keeping the users up to date. And to know whether we are more like at the 40% or the 90% progress mark.
In the meantime, we can go back to reading the classics and assuming that some of the following has happened:
The Big Rewrite
Rewrites Considered Harmful
Second-System Effect (also on Wikipedia)
Let's hope you guys have it under control.
kaidoe
Thu Mar 16, 2017 8:22 pm
+1 IGMP snooping, and full support for IPTV/multicast :)
Cheers !
Wyz4k
Tue May 16, 2017 6:00 am
I too would love to have this to start testing LTE on MC7304.
RogerWilco
Tue May 16, 2017 6:45 am
+ 8.8 million for the MC7304.
jenechka
Tue May 16, 2017 2:04 pm
+ 8.8 million for the IGMP snooping
nz_monkey
Tue May 23, 2017 1:43 am
Any time now guys... ;)
Only 4 years overdue.
juliokato
Tue May 23, 2017 4:31 pm
By chance will version 7 not run on soho devices?
pe1chl
Tue May 23, 2017 4:52 pm
Was this presented on a MUM? Was it by MikroTik?
Chupaka
Tue May 23, 2017 5:37 pm
Yes, it was on MUM. On US MUM in 2014 :)
https://mum.mikrotik.com//presentations/US14/ccrros.pdf
paulct
Tue May 23, 2017 6:42 pm
Too many bud lights that day....
Railander
Thu Jun 01, 2017 11:11 am
ack
Sun Jun 11, 2017 12:40 am
Dear MikroTik team and Dear Developers,
Like most people here, we are waiting ROS v7.0 like our Christmas toy, but although the wait has been long, we won’t blame you. Everybody that had to manage a complex programming project will know that it takes a lot of time and effort to get proper work, especially when having to interact with RFC and many not-so-standard features to include.
My one and only concern (for improvement) is the lack of communication and vision from the company itself. While we do not expect to get a date if you can’t commit, we could be all interested to know what is going on behind the curtains. We all know that we will have to wait for a proper result, but there is for sure a roadmap, goals and tracking of them.
Unlike most other vendors, MikroTik is way more than just a brand. It is a different attitude, a real community and a very versatile and flexible system. I wished with ROS v7.0+ that the hardware becomes as well more high-end with more high-speed port density, while keeping very cheap entry-level devices too, so we can have one experience from SOHO all the way to carrier-grade routers.
However, we have not given up and we look forward to hearing soon that somebody big is coming.
/troll on
/troll off
Milan
Tue Jul 11, 2017 12:25 am
I have small LAN and my provider gives me IPv6 /64 network, but I'm not able to use it in my internal infrastructure yet (I have few routed LANs with UTP and WiFi).
Also I have bigger LAN, where I do NAT for IPv4 and when something change, I'm not able to fix IPv6 at the same time as IPv4, as I have no NAT for IPv6. This drives me crazy and is a showstopper why to not deploy IPv6 at every place it could be (until RouterOS with IPv6 NAT). Also this is a reason why to not use/suggest Mikrotik at all.
You need to talk to your provider. This is insane! We certainly need to avoid getting NAT everywhere for reasons
like that. I get a /48 from my provider on a consumer connection, which can be argued to be a bit large, but any
provider should at least give a /60 or /56 to a customer that has a (home) router.
/64 can only be reasonably given to e.g. a rack in a colocation environment where the provider does the routing.
Do not mess up IPv6 NAT (wich is must have)[1] and IPV6 masquerade (not needed).
[1] what I have to do when something breaks and I have to move service/server in internal LAN? I simply do NAT (1:1), but it is possible with IPv4 only, not with IPv6. This is why one needs IPv6 NAT (to be able to do a fix in minutes/seconds, not in hours because of IPv6 address change and DNS caching issues).
normis
Fri Jul 14, 2017 11:07 am
Already in v6
*)bridge - implemented software based "igmp-snooping"
pe1chl
Fri Jul 14, 2017 12:19 pm
I agree that it is useful to have IPv6 prefix translation (1:1 NAT of entire /64 networks) but that is not related to your "my provider gives me IPv6 /64 network"
which cannot be worked around by prefix translation (when you want to have separate networks for yourself an guests, for example, or want to route internally).
Providers that give only a /64 to their customers really need to study IPv6 again and re-do their rollout before it is too late.
It should not be the task of router manufacturers to devise all kinds of workarounds for situations like that.
For prefix translation, there are some good use cases. Also see the writeups done by user ZeroByte about this matter.
jenechka
Mon Jul 31, 2017 3:56 am
Already in v6
thank you so much, how to configure this feature to work correctly?
Insanityflea
Fri Aug 25, 2017 8:10 am
I'm just waiting for more LTE driver support which on the wiki states coming in ROS V7. At this rate I might as well look for another device haha.
Xtreme512
Sat Sep 02, 2017 7:45 pm
as of feb 2017, cake took place of fq_codel now. as in the description of cake, it looks like PCQ to me (equal bandwidth in src, dst address).
There is piece_of_cake for trees I guess... I wonder what are the differences between HTB that we use in routeros.
jspool
Sat Sep 02, 2017 9:15 pm
If they rush a alpha level product out the door the response would be more negative as many expect it to work near perfectly upon release. I hope that they use it internally for the time needed to work out the basic bugs prior to a public release. Of course the longer they wait to release the more is expected from the release as people are looking at the amount of time it has been under development.
Once released the myriad of users will use it in varying ways that testing cannot simulate and then the real bugs can be worked out.
russman
Wed Sep 06, 2017 7:44 pm
In the pdf you referenced from 2014, it talks about, v6.8 I haven't seen anything beyond 6.41 in RC or beta yet in 2017. Where are these being released at?
jspool
Wed Sep 06, 2017 7:53 pm
6.8 was released in Jan of 2014: What's new in 6.8 (2014-Jan-29 15:52)
As math goes 41 is higher than 8.
Anyway thanks for the chuckle.
ziegenberg
Fri Sep 08, 2017 9:42 pm
Do not ask for v7.0 beta1, instead ask for 7.0 alpha. Maybe we'll get a different answer...
blackmesawireless
Thu Sep 14, 2017 11:41 pm
Starting to think it's the Duke Nukem Forever of RouterOS. :(
It'll come out about a decade after it was expected and suck.
patrick7
Mon Sep 18, 2017 8:20 pm
Any news?
JimmyNyholm
Thu Sep 21, 2017 2:17 pm
An alfa to play in the lab would be most welcome.....
maara
Sun Oct 15, 2017 9:54 pm
This is getting ridiculous....
patrick7
Sun Oct 15, 2017 11:16 pm
Stop asking and switch to another vendor :lol:.
nadeu
Wed Oct 18, 2017 8:40 pm
I'm currently switching to another vendor. Cumulus on ONIE + router.
More than 240Mpps of performance, tested. ;-)
7Tb/s with prefixes that are loaded on TCAM module.
Regards,
patrick7
Thu Oct 19, 2017 12:20 am
I have replaced CCRs mostly with Supermicro 5018D-FN8T + debian + FRR. Works like a charm.
Murmaider
Thu Oct 19, 2017 7:52 am
Regards,
What vendor has routers with ONIE?
I thought this was only for sdn switches.
jmginer
Sun Nov 05, 2017 1:36 pm
We bought a year ago a CCR1072,
We are using with 4 peers providing us full routing and with more than 800 filters.
After a reboot, it takes more than 2 hours to apply all routes and filters and it's only using 2% of CPU.
Resume: Sh it product.
nz_monkey
Sun Nov 05, 2017 8:29 pm
That is a lot of route filters for such a small number of peers !
jmginer
Mon Nov 06, 2017 4:42 pm
One peer is IX point, with a lot of members.
+300 filters based on different members of the IX and for different /24 subnets.
+500 filters setting a BGP-Local-Pref based on the BGP-AS-Path.
pe1chl
Mon Nov 06, 2017 11:47 pm
The problem is that it has a 72-core processor but the BGP update task is single-threaded so it uses only 1 of the 72 cores.
The remaining cores are available for routing.
It is apparently not so easy to write a multithreaded BGP implementation, the easiest is to have a separate thread for each instance but that will probably not buy you much.
In circumstances like this, the router would benefit more from a higher clockrate than from so many cores.
alibalalo
Wed Nov 08, 2017 10:45 am
Please find a solution to the programs and hide the MAC and find a solution to the problem of connecting tp Link WDS
alibalalo
You must find a solution to the problem of Internet theft through the Mac
ZeroByte
Thu Nov 09, 2017 10:17 pm
MAC-based authentication/accounting is broken in general because it is trivial to spoof MAC addresses. The solution is to utilize some higher level of AAA such as PPPoE or WPA2-Enterprise
jenechka
Wed Nov 22, 2017 6:31 pm
Already in v6
how to configure it ?
Chupaka
Thu Nov 23, 2017 7:28 am
Currently available only in 6.41rc
[admin@RouterOS-Testing] /interface bridge set 0 igmp-snooping=
no  yes
StubArea51
Trainer
Trainer
Wed Dec 06, 2017 7:08 pm
Dear Santa Claus,
I would like RouterOS v7 for Christmas :-)
juliokato
Wed Dec 06, 2017 7:27 pm
Dear Santa Claus,
of which year?
patrick7
Wed Dec 06, 2017 8:11 pm
I'm sure we'll not survive that year.
gringoZ
Thu Dec 07, 2017 12:25 pm
Dear Santa
This year i would like a intel i210 nic support at mt ros 6.x or mt ros v7 (is exists)
please please see my post from past: viewtopic.php?f=2&t=94834
we are very patient...
jarda
Thu Dec 07, 2017 2:50 pm
Dear gringo,
Santa is also only a man. This Christmas you can get 6.40.6 at maximum, if you behaved well all the year. Please, stay tuned and train your patience.
Your Santa.
StubArea51
Trainer
Trainer
Thu Dec 07, 2017 5:02 pm
Dear Santa Claus,
of which year?
2017...I'm hoping for a Christmas Miracle :lol:
cgood
Fri Dec 08, 2017 12:59 pm
Just for an example. Less about OpenVPN TCP. We have more than 100 connected clients (ROS/Linux devices) to CHR (1G RAM P1 lic) - all use TCP. Speed-test between two VPS connected to CHR via ovpn-client:
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-10.00  sec  22.8 MBytes  19.1 Mbits/sec   41             sender
[  4]   0.00-10.00  sec  22.0 MBytes  18.4 Mbits/sec                  receiver
[  6]   0.00-10.00  sec  14.1 MBytes  11.8 Mbits/sec   38             sender
[  6]   0.00-10.00  sec  13.4 MBytes  11.2 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec  36.9 MBytes  31.0 Mbits/sec   79             sender
[SUM]   0.00-10.00  sec  35.4 MBytes  29.7 Mbits/sec                  receiver
iperf Done.
And with all nice features of OpenVPN we with impatience expect UDP support 8)
shaoranrch
Fri Dec 08, 2017 3:42 pm
+1 On this request, please tell us when, the faster you release the faster we can test and give feedback for you to perfect it.
I mainly work in the carrier side, we use MikroTik a lot but some things we do miss, specially related to the BGP and MPLS side...
Your brand has been quickly evolving from a "well I know it I use it in some small projects" to one that powers backbones of not-so-small ISP and DC networks, it's also used in research fields and to build systems for harsh environments (I saw "internet bots" in a coal mine powered by MikroTik).
We really need all the promises (and more) made for this version.
freemannnn
Forum Veteran
Forum Veteran
Fri Dec 08, 2017 3:58 pm
that reminds me of apple with IOS11. full of bugs for new features that some care and some dont care. i prefer an IOS10 shiny than a shitty IOS11. fortunately i stayed at 10.3.3 on my iphone.
and not to forget IOS11 removed showing mac address of devices in usefull aplications like FING, NET ANALYZER.
patrick7
Fri Dec 08, 2017 6:10 pm
Stop asking, you're wasting your time...
Switch to plain linux, problem solved.
Steveocee
Fri Dec 08, 2017 10:20 pm
Mikrotik wont release a v7. There is so much hype built over it that it won't surprise me if they completely jump a gen to 8 or even go all out and release a new naming convention.
v7 is the embarrassment of the family mocked heavily by all within the MikroTik community.
Fair play to the devs though for constantly working on current software and not leaving us in the lurch whilst they develop new stuff.
WireDick
Sun Dec 10, 2017 3:33 pm
Could we expect hardware acceleration AES for RB3011UiAS-RM?
Could we expect a setup assistent for IPV6 Nat in Router OS?
Kind Regards
Cha0s
Mon Dec 11, 2017 4:00 pm
Not before v7. Even after v7 I am not so sure they will add HW AES support. The CPU does support it, but MikroTik don't seem to want to invest in RB3011.
They never released any other model as they did with the various models of RB2011...
ZeroByte
Tue Dec 12, 2017 8:04 pm
IPv6 NAT - I bet we have to wait longer than the IGMP snooping people waited before it comes out. . .
If Mikrotik _does_ decide to add this in, I would request the following flavors (most-preferred first)
- NAT64 protocol translation (stateful)
- NAT64 protocol translation (stateless)
- NAT66-PT (stateless prefix translation)
-NAT66 (dstnat) - This is useful for things like transparent service redirection
- NAT66 (srcnat many-to-1) - this one I could be happy if they never implemented. I'd prefer for the IPv6 community to never deploy in a way that requires this because once it's there, the wound can never be completely healed.
Vooray
Sat Jan 06, 2018 7:57 pm
Up :)
It is 2018 already. May we have some status report or plans on v7 release? Or it is abandoned already?
mistry7
Sun Jan 07, 2018 9:03 pm
Looks like it is Canceled.....
Nothing in the last 4 years
So we are Stil on Kernel 3.xx.xx
telcouk
Mon Jan 08, 2018 4:03 pm
I think we can safely assume that v7 is some way off, with Mikrotik staying tight lipped on a release date.
Indicating that they themselves have no idea of when it is going to be released.
We are getting to the stage where we are outgrowing our Cloud Core routers, yet we’re only doing 10-100Mb of traffic typically throughout the day! What is killing us is BGP updates, causing jitter / latency spikes on our network… We have a total of 3 full BGP feeds on a total of 4 Mikrotik Cloud Core routers.
Unfortunately, we have lost patience with Mikrotik and we are in the process of exploring alternatives. We won’t be purchasing further Mikrotik products which require BGP.
I really do think they should spell out the limitations of BGP… As on paper everything looks amazing with the Cloud Core routers, however the reality is VERY different.
ste
Mon Jan 08, 2018 5:03 pm
Not noticed this BGP generated jitter/latency so far. Searched the forum and did not find something regarding this. Did you post/discussed this problem?
ZeroByte
Mon Jan 08, 2018 5:12 pm
I think he's referring to the fact that BGP runs in a single thread - ergo cannot take advantage of multi-core tile platform. It could be that during convergence, his network performance is spotty due to various reasons, but that's just speculation on my part. At the end of the day, though, there have been many "oh that will be fixed / added / addressed in ROSv7" issues - more than I can recall, really.
zyzelis
Mon Jan 08, 2018 7:34 pm
+1
to say more: we already moving out from mtik wireless, now after some accidents bgp routers are on the way.
patrick7
Mon Jan 08, 2018 7:54 pm
Maybe we should collaborate and make a list of alternative devices / software solutions?
As a start:
CloudCoreRouter
- 6x Gigabit Ethernet (RJ45)
- 2x 10 Gigabit Ethernet (SFP+)
- 16GB RAM
- Xeon-D 1518 Quad Core
RB75X
PCEngines APU2
- 3x Gigabit Ethernet
- 4GB RAM
- 1 GHz Quad Core X86
BGP/OSPF/MPLS done with FRR, multiple fulltables no issue.
mistry7
Wed Jan 10, 2018 5:36 am
We are lucky and dont buy Mikrotik CCR for BGP....
http://mum.mikrotik.com/presentations/RU14/megis.pdf
But for all other, this Dokument is 4 years old and still nothing...
The most CCR for BGP would sorted out before they will release v7
so the problems also resolve themselves, no more need for ROS v7
I am also looking for an alternative for Mikrotik Wireless, because of missing
- spectral scan
- Nv2 bad performance in 802.11ac
- missing innovation
- missing Sync
- Limitation in Channel width
After 14 years with MIKROTIK this is not easy. Our hole Netwotk is Mikrotik based,
But they don't here and don't care the needs in Wireless Market, so we have to look to another Brands!
Pity, but reality
Mistry7
honzam
Wed Jan 10, 2018 10:12 am
- spectral scan
- missing Sync
Pity, but reality
We have the same problem with wireless :(
We don´t use BGP on Mikrotik . The main problem is the old wireless kernel 3.0 in ROS V6
WireDick
Fri Jan 12, 2018 12:48 am
Can someone explain me why they just can't enable Hardware accelartion for AES in rb3011 for example as Routerboard update or license buy option???
We have 18 of them mostly for managing sophos / Cisco / Siemens stuff etc. .... via openvpn and during the last months with growing network complxity we run into bandwith issue ....
patrick7
Fri Jan 12, 2018 1:57 pm
Don't expect anything kernel related to be fixed in v6.
mistry7
Fri Jan 12, 2018 6:05 pm
And don´t expect fast Release of ROS7,
we are now at 4.14.xx how long we will see Kernel 4?
Linux Kernel 5.0 Will be Coming in the Summer of 2018
Mikrotik is 4-5years behind development!
Chupaka
Sat Jan 13, 2018 7:12 pm
RHEL 7.4 uses kernel 3.10.0-693. How many years are they behind development? :)
mistry7
Sat Jan 13, 2018 9:59 pm
right....
But RHEL 8.0 is on the way based on Fedora 27 aka Linux Kernel 4.14
s9date
Sat Jan 13, 2018 11:54 pm
Hello. I have 11 Mikrotik 912 + Sierra MC7304. I too would love to have this to start testing LTE on MC7304. Thank you.
RogerWilco
Tue Jan 16, 2018 3:35 am
I only have 1 of each, but I'd love to be able to use LTE too.
wilsonlmh
Wed Jan 17, 2018 8:34 am
No, I'm still waiting for VirtIO support in v7
mark73
Thu Feb 08, 2018 5:01 pm
ROSv7 will be released just after Duke Nukem Forever!
*SCNR*
mrz
Thu Feb 08, 2018 5:33 pm
DNF was released in 2011, so ...
juliokato
Thu Feb 08, 2018 6:51 pm
No comments....
kkk
:wq!
Chupaka
Fri Feb 09, 2018 7:59 am
So it's time for ROS v7!
jarda
Fri Feb 09, 2018 9:06 am
Apparently not yet. Don't you remember the well known sentence of Normis? "When it will be then it will be." :-)
patrick7
Sat Feb 10, 2018 12:34 am
After waiting 5 years, I think it won't ever be released.
pe1chl
Sat Feb 10, 2018 11:55 am
They have moved themselves into incredible difficulty by raising the expectations so much....
When v7 would just have been a move to a new kernel that would then allow the gradual introduction of new features that required that new kernel,
and in parallel to the usual changes like we now see in the 6.x series there would be some "experimental packages" that introduce radical changes
(like the mighty new routing code), everything would have proceeded smoothly.
And it has been done before. Autorouting has been an experimental package before, and several packages for Wireless.
After some feedback and development, these respective packages became part of the standard distribution.
But now, v7 is kind of a magic bullet that promises to fix many issues and limitations, and of course it can never be completely ready for release
(without bugs and loose ends). So no matter how long it is postponed, there will always be a lot of disappointment and support calls. And by now
it is much too late to go back to the more gradual migration as described above. At least under the designation RouterOS v7.
Paternot
Forum Veteran
Forum Veteran
Sat Feb 10, 2018 4:58 pm
And by now it is much too late to go back to the more gradual migration as described above. At least under the designation RouterOS v7.
Well, there is always RouterOS v8... :D
patrick7
Sat Feb 10, 2018 9:05 pm
Release of v8 will be in ~ 40 years if they proceed with the same speed.
pe1chl
Sun Feb 11, 2018 12:14 pm
I think it refers to the option of skipping v7 altogether and then proceed the way described above.
(i.e. make v8 a v6 with current kernel and then incrementally build from there just as done in v6.xx releases)
Paternot
Forum Veteran
Forum Veteran
Mon Feb 12, 2018 3:19 am
Yes, that's it. I just think V8 should come with a new kernel - and the rest should be improved sequentially. The worst part of a new kernel are the hardware drivers. The rest is, for the most part, high level enough to not be directly affected by it.
bearmeister
Thu Feb 15, 2018 5:58 am
And yet, they are still able to deliver a working stateful DHCPv6 server, irony much?
Meanwhile, Mikrotik who are supposed to be in the SP space can't deliver a decent BGP or a working DHCPv6 server.
ROS7 has been thrown around so much over the years as far as I'm concerned its just vaporware, I'll believe it exists when I see it.
Until then, I like others, will continue to explore alternative that meet basic industry requirements.
Sob
Thu Feb 15, 2018 6:21 pm
When v7 would just have been a move to a new kernel ...
It's pure speculation, but I think that "just switching kernel" might be the problematic part. If they modified too much in the old one (and it looks like a lot of what RouterOS does is not just in userspace), porting everything forward can be hard. Linux is evolving, and it's being worked on by many people, much more than MikroTik has (I guess). So they can either break from it, go own way, and lose all those nice improvements already done by someone else. Or they can try to keep up with changes, port their stuff, but that can be an awful lot of work.
Paternot
Forum Veteran
Forum Veteran
Fri Feb 16, 2018 9:49 pm
I'm not sure about that. The drivers are kernel bound, of course. So are the NV protocols - with all that TDMA and whatnot. But (almost) everything else? Is just userspace. Even routing: you change it in linux with a userspace command. The kernel may change as much as they want - the interface is still the same.
Even things like L2TP shouldn't be a problem: You still talks to the kernel through a userspace interface. IPv6, PPP, OpenVpn, IPSec... everything is userspace controlled. Yes, yes. OpenVpn creats an interface (tun or tap). They are provided by the kernel, and are userspace controlled. If the Linux kernel was ported to a given architecture, chances are they're already available.
The drivers... well, the drivers are the hard part. If they aren't part of the kernel three, then Mikrotik must get them, compiled to the new kernel, from the hardware makers. And this is not always easy... Then they need to test, test, test, integrate, validate... a truly hellish task.
I agree with what was said: they promised too much, and now are trying to live up to their promises. This means a lot of development, in a lot of packages. And the drivers! Have I said how hard the drivers part will be? :)
Sob
Fri Feb 16, 2018 10:40 pm
I'm not sure either (and I hope I made it clear enough).
My basic argument is that used kernel was said to be limiting factor for adding some new features years ago. So it would make sense to upgrade it, and not wait for too long before doing so. Not only can the new version already have some wanted features built-in, but also hardware manufacturers are more likely to support current kernel in their (not yet built-in) drivers, if we're talking about newish hardware. If there was only relatively small amount of modifications made by MikroTik, then why hold off for so long?
I'd also say that there's a difference between controlled from userspace and being in userspace, but I can't really go far with that, because that would be too thin ice for me.
I doubt that MikroTik will share exact details, so speculations is the only thing we have. Other than just waiting, but it's a little boring already. ;)
Paternot
Forum Veteran
Forum Veteran
Sat Feb 17, 2018 12:22 am
I don't know. Just passing time, with idle speculation. :D
mhugo
Sat Feb 17, 2018 10:57 pm
We have been waiting too long for basic SP features like multithread BGP and something as simple as DHCP Option 82 Circuit ID. I think that if Mikrotik showed that anything was actually happening it would be easier to not look at other vendors.
jarda
Sun Feb 18, 2018 12:12 am
This is always possible and I encourage you to do that. There is free competition on the market and you should spend money on the products that fits your needs the best.
thobias
Mon Feb 19, 2018 12:29 pm
+1
We are also now in the process of throwing out everything Mikrotik running BGP as it cannot handle it.
patrick7
Mon Feb 19, 2018 5:48 pm
We too. Using SuperMicro Xeon-D appliances with debian and FRR. Works like a charm, BGP with X fulltables, VRF (v4/v6), Route Leaking, ...
netravnen
Tue Mar 06, 2018 2:09 pm
Looking away from RouterOS v6.x running IPv6 BGP [tables]?
Not being able to verify IPv6 routing table (when not main table!) is really a big deal. (But seeing the routes exists by the number the route counter shows. :sigh:)
And doing policy routing rules for anything else than main table in IPv6.
It feels a bit poorly planned/immature(still?) when compared to I can do the WHOLE vrf-mpls infrastructure with IPv4. But it is only partially implemented with IPv6 (vrf's?) in RouterOS v6.x. :/
Still looking for equalized feature set between IPv4 and IPv6 in RouterOS version 7 or 8(?) in 2020 or 2025(?)
@Mikrotik: Would be nice with a roadmap somewhere telling all us customers which year to expect the release of the first release candidate for the next major release of RouterOS. (Currently it feels sort of I'm/we are left out to dry just looking/scraping for news about the next major below the earths horizon and outer space past the planet of Uranus.)
Would REALLY appreciate a lot more openness compared to fx when GitLab.com encountered extended downtime for days due to an engineers non-intended blunder while doing maintenance that fateful day last year (2017).
Cha0s
Tue Mar 06, 2018 2:19 pm
Didn't you hear? Almost all v7 features have been backported to v6!
Doesn't matter that routing (bgp), ipv6, drivers and all necessary 'routing' stuff cannot get backported due to old kernel version in v6. At least we now have kids control and detect internet! Super essential features for routers running BGP in the public internet :lol: :lol:
netravnen
Tue Mar 06, 2018 2:39 pm
No. I have not (before now) stumbled across that information.
So looking forward to when RouterOS will support SR !
carlhjerpe
Wed Apr 04, 2018 1:42 pm
If we draw some conclusions:
  1. Almost everything from 7.x has been backported to 6.x
  2. MikroTik has been in trouble about GPL
  3. It's been in development for a long period of time
  4. Linux has dropped TILE support
Could it possibly be that they're moving to something that isn't GPL licensed?
Just saying, there are options that aren't Linux.
mtsphere
Thu Apr 05, 2018 3:11 am
I'm sure that this will never happen... Much like IS-IS..
Somehow i'm sad that many people are leaving MT platform (numerous reasons) since i'm following and using MT basically from the begging.
Number of our customers moved to Quagga / Bird just because BGP glitches.. They waited.. but - Big Foot (v7) never came around..
Cheers
ziegenberg
Thu Apr 05, 2018 11:24 am
As mentioned several times on this forum, this does not apply as MikroTik did not use the linux community TILE code in any way. They do not rely on the TILE support of Linux at all.
cheeze
Sun Apr 15, 2018 10:04 pm
Mikrotik, please please please please.
Leave the development of *NEW* features/things/whatnot out of ROS 6 now. Please, move the developers out of ROS 6 feature development and have them go to ROS 7 development. Bugfixes should still keep going on ROS 6 as they are going now (if possible).
There needs to be a harder development push towards ROS 7. If there's nothing else to develop for ROS 7 (which I have high doubts on as I know more and more features are being added to it all the time), then can we please get a glimpse of how things are going with it. I think we can all more or less surmize that Mikrotik is probably building an entirely new routing stack from scratch and that it is taking far more amounts of time than anyone ever expected. As much as it is feasible, can more people be thrown at developing ROS 7 instead of adding more features to ROS 6?
jarda
Mon Apr 16, 2018 3:43 pm
Déjà vu?
Don't we remember the transition years between the version 5 and 6?
dynek
Mon Apr 16, 2018 3:51 pm
Well if they say they backported most (all ?) v7 functionalities into v6, I don't really see a problem here.
mistry7
Mon Apr 16, 2018 4:28 pm
The problem is the old kernel ROS 6 based on, there much improvements only possible with newer kernel.
And we will see ROS 7 with 4.xx Kernel when Linus Towards launch Kernel 5.xx, happens probably this summer....
And the delay will getting bigger.
All new products with IPQ have driver throughput problems, Mikrotik works with a back ported driver, it would be easier to use the origin one,
but it is only available for newer kernels...
here the delay takes its toll
pe1chl
Mon Apr 16, 2018 9:12 pm
It becomes more clear that the kernel has been so heavily modified that it is not so easy to upgrade it anymore.
This is of course always a tough decision: do you limit the kernel changes and try to forward them to the kernel development group, which will cause a lot of wasted time due to discussion about how to implement some feature, or do you just "fork" the kernel based on some version uptodate at that time, causing the problem there is now.
On the other hand, when you do all the work on a forked kernel, you are not affected by decisions like the dropping of TILE support in the kernel.
honzam
Mon Apr 16, 2018 9:56 pm
Maybe Mikrotik wait for kernel 5.x :)
jarda
Mon Apr 16, 2018 11:06 pm
... Just to start waiting for the 6.x kernel...
mistry7
Mon Apr 16, 2018 11:18 pm
right, and then hang on old drivers, that is exactly what happend
The problem Beginns if you has to support up to date Hardware with this old software!
And now we are standing in the rain, Mikrotik has no timeline for Ros7, flawless ARM Wireless driver, Spectral Scan........
cheeze
Tue Apr 17, 2018 12:35 am
I am still not sure why Mikrotik didn't go with IP Infusion....
CTSsean
Thu Apr 26, 2018 5:37 pm
so 15 years from version to version. Nice... so we only have another 11 years.
nz_monkey
Fri Apr 27, 2018 12:12 am
That is not the problem.
The problem is getting a modern kernel that boots on all of the platforms while supporting hardware offloads.
Just my opinion...
cheeze
Mon Apr 30, 2018 12:19 am
Just my opinion...
To be honest, I think it's both. However I think what you bring up is likely more of the issue though.
I wonder if it's worth it for Mikrotik to just focus on like.....x86-64/ARM/TILE going forward. Not sure if the MIPS devices are still supported to be honest. I also have been hearing that TILE is no longer going to be a supported hardware platform. Which sucks.
jarda
Mon Apr 30, 2018 10:15 am
It was written several times here. Future versions of ros will be running on tilera further. Ros is not affected by this.
normis
Mon Apr 30, 2018 10:29 am
RouterOS uses very little of open source code. MikroTik is in direct relationship with the CPU manufacturers. We use the official drivers and code. We don't use open source code.
mistry7
Mon Apr 30, 2018 10:44 am
Then explain the difficulty's with migrating on to newer Kernel.....
normis
Mon Apr 30, 2018 11:56 am
This is the difficulty :D If we were using all open source code, it would be easy to upgrade. Now we must only rely on ourselves to upgrade all programs.
Vitis
Mon Apr 30, 2018 4:04 pm
Do you have any timeline? We are waiting more than 4 year for the VRF support :?
lillecarl
Mon Apr 30, 2018 4:09 pm
Is RouterOS 7 going to ship a Linux kernel?
levicki
Tue May 01, 2018 11:56 am
MikroTik (just like Ubiquiti and many others for that matter) are depending on the hardware (CPU/chipset) manufacturer for major upgrades. Those manufacturers are the ones who provide SDK and drivers (the latter usually in binary form only due to patents), and those drivers cannot be loaded on newer kernel without recompile. If the manufacturer does not supply updated binaries and SDK they cannot update anything.
patrick7
Fri May 18, 2018 3:13 pm
While I understand it needs some time to make good software, it's getting embarrassing with v7 (or its promised bugfixes). Since 2013 MikroTik promises to fix bugs with v7 (recursive ipv6 nexthops etc), and absolutely NOTHING happens. I'm sorry, but such a product is absolutely unsuitable for professional use.
Florian
Fri Jun 01, 2018 2:50 pm
To be fair, some of "wait for v7" problems were in fact corrected in v6.XX (like more options for DHCPv6 Server)
My theory is that they didn't plan to push v6 this far, and they realised that SOME of v7 features could be in fact in v6, so this "helped" delay V7.
Now, Mikrotik is not a small fish, but they're not Cisco or HPE/Aruba. If V7 is a major overhaul, I can't image the hour/man needed to do that.
pe1chl
Fri Jun 01, 2018 3:17 pm
That is why it is often impractical to develop software that way.
Announcing a new version that is to be "rewritten from scratch" or similar claims usually results in failure.
Gradually developing new features and maybe rewriting some subsystems one at a time has more chance of succeeding.
Probably a chance to survive this mess is to make a release that aligns the kernel with a reasonably current version and
then work from there on replacement of the subsystems that were announced to be rewritten. However it will be impossible
to release such a change as "v7.0" because there will be a big flood of "you announced it will be fixed in v7 and now we have
v7 and it is still not fixed!" complaints. No idea how to work around that. Go to v8 immediately, change the version naming
(like Microsoft did many times) so it is e.g. called "RouterOS 2018" or "RouterOS Vista"?
Paternot
Forum Veteran
Forum Veteran
Fri Jun 01, 2018 6:28 pm
I agree that would be the best way to handle this.
About the problem of "You said it would be done on V7!": Make the version 7 a big announcement. Keep telling about the improvements the new kernel would bring. And - here is the thing - create a roadmap. Something like this:
V7.0 -> Inicial release. Low level kernel/drivers work.
V7.1 -> Subsystem "X" revamped.
V7.2 -> Subsystem "Y" revamped. Feature "Z" included. Long pending limitation "W" addressed.
Better than trying to deliver whole mythical unicorn. V7.X to V7.Y would be like V4.41.X to 6.42.X, in terms of time and development.
How about?
juliokato
Sun Jun 03, 2018 6:06 pm
I just want to get an idea of how much this unicorn will give birth.
R1CH
Tue Jun 05, 2018 4:17 pm
Why is Mikrotik so against using open source software? We would have working 802.11ac Wave2, 5 GHz spectral scan, OpenVPN UDP support, more secure smbd, httpd, etc if Mikrotik would stop re-inventing everything in-house and use well-tested open source software. You could combine open source kernel with proprietary modules for hardware offloading etc in much the same way NVIDIA provides proprietary Linux graphics drivers for their chips.
pe1chl
Tue Jun 05, 2018 4:26 pm
One reason is probably that when you use opensource software and keep tracking all the updates, you end up with more and more bloated software that does not fit into a space-limited router anymore.
It works fine on the PC platform where space and other resource usage (CPU) has grown with the code, but on embedded hardware it is a bit more difficult.
Remember the current routers mostly have only 16MB of flash space!
(the previous generation usually had 128MB which was a bit more generous, but to store generic opensouce software for all functions you would need more like 512MB-1GB in my experience)
Paternot
Forum Veteran
Forum Veteran
Tue Jun 05, 2018 4:48 pm
I don't see all this bloat. Well, not at where we talking: low level, kernel, drivers and servers. Take a look at the RaspberryPi: Full OpenSource, ARM, Linux kernel. This is fdisk usage from one I have access to (default install, with graphic desktop and full updated).
df -h
Sist. Arq. Tam. Usado Disp. Uso% Montado em
/dev/root 15G 4,6G 9,4G 33% /
devtmpfs 370M 0 370M 0% /dev
tmpfs 375M 0 375M 0% /dev/shm
tmpfs 375M 9,9M 365M 3% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 375M 0 375M 0% /sys/fs/cgroup
/dev/mmcblk0p1 41M 22M 20M 53% /boot
tmpfs 75M 0 75M 0% /run/user/1002
tmpfs 75M 0 75M 0% /run/user/1001
I am using 4,6GiB of disk space. Not that bad.
True, it doesn't have OpenVPN and everything else installed - but it would not use more than 1 GiB. Even if it used 3 more GiB: It would be still using less than ROS.
So, no. To me is more about control. If they build it, they can guarantee the software through the expected life cycle of the product.
If it is a good idea, if this costs less resources than going full OpenSource, if the competitive advantage is worth the trouble (even if there is one or not) is another problem - and a strategical decision to Mikrotik.
Wyz4k
Tue Jun 05, 2018 5:37 pm
3GB is less than ROS? ROS is 20-40MB...
pe1chl
Tue Jun 05, 2018 6:05 pm
I think you somehow are confusing MB and GB here. Quite common these days!
juliokato
Tue Jun 05, 2018 6:17 pm
many people also confuse bit (b) and byte (B) for traffic analysis.
Chupaka
Tue Jun 05, 2018 6:36 pm
many people think that if 1 megabyte = 1024 kilobytes, then 1 megabit per second = 1024 kilobits per second :)
Paternot
Forum Veteran
Forum Veteran
Tue Jun 05, 2018 9:58 pm
LOL True enough. Things move so fast, we lost track of these things. Nowadays we carry in the pocket a mobile with 4GiB of RAM - and my first computer had 16KiB of RAM... Sometimes is enough to make lost track of things... :D
R1CH
Wed Jun 06, 2018 2:22 pm
I don't really buy this argument. Linksys, DLINK, etc all use open source software and have no issues selling $50 routers with enough disk space to support all these packages. With good compilation options and stripping of binaries it's possible to get very small versions of many popular packages. And as you say, Mikrotik used to have plenty of disk space with their products, only recently have they been skimping on the NAND size.
brotherdust
Re: RouterOS v7.0 beta1 - when?
Fri Jun 08, 2018 12:24 am
I think @levicki is correct about being beholden to the manufacturer's release cadences. Most manufacturers of embedded networking kit are still hanging out on kernel 3.x. It's really annoying! If any manufacturer is reading this: STOP DOING OUT-OF-LINE KERNEL RELEASES. UPSTREAM YOUR CHANGES.
I digress...
In terms of features, at release, ROS 6 was in the unique position of supporting some fairly advanced scenarios; but these had to be developed in-house. Since that time, much effort (and a LOT of money) has been put in to the Linux network stack, especially in the v4.x series. As a result, vanilla Linux kernel can do almost everything ROS can do, and more besides. ROS can't leverage those developments unless they backport the features from v4 kernel to v3 kernel, because most manufacturer SDK's are, as mentioned previously, still stuck in kernel v3-land.
So, all this to answer the question, "When?" My gut tells me that it won't happen until it's more painful to maintain ROS v6 than it is to start over and leverage open-source efforts better. As ROS v6 continues to age, use-cases in [newer, more complex, software-driven] environments will shrink; to the point where it's only useful for very small providers, small business, and home users.
From where I'm standing, as a service provider, the competitive landscape is changing rapidly. To survive, I must be able to offer new services my customers are demanding as quickly as possible. Right now, my biggest limiting factor in delivering those services is RouterOS. I really, really love RouterOS, but it's not growing with me and, sadly, I don't think Mikrotik is all that interested in what we have to say.
Evidence:
- Numerous attempts to solicit ideas for future products from the forum community (see: viewtopic.php?f=2&t=121533&hilit=flagship+router), then basically ignoring it and going a different direction
- Continued focus on last-mile and switching-type devices and software supporting said devices
- Inability and/or unwillingness to maintain a coherent feature request list (see: https://community.ubnt.com/t5/UNMS-Feat ... reRequests as an example of how to do it better) that the community can vote/provide feedback on
Am I wrong? Possibly. I'm trying to be as objective as I can in this analysis; but I'll admit I'm at the point of "believe-it-when-you-see-it".
nz_monkey
Fri Jun 08, 2018 3:10 am
I agree with almost everything @brotherdust has said above, his comments match my own feelings on the current state of Mikrotik.
I have been a huge fan of Mikrotik's RouterOS, but I am using it less and less. The service provider market has kept evolving but RouterOS has not evolved with it.
Mikrotik had a lot of momentum with RouterOS and Service Provider features, e.g. they moved from Quagga to their own Routing engine and added MPLS features during the 3.x and 4.x phase, and then it all just stopped during the 5.x phase. That was over 7 years ago now!
Mikrotik's sales are growing and they are focusing on the areas where they see growth, but that does not mean long term success.
This reminds me somewhat of Toyota thinking they could keep growing by making variations of the Corolla and Camry, so they stopped producing cars like the Celica and Supra, but what they did not realise was that while sales volumes for the Celica and Supra were low, they were the "hero" cars that were attracting buyers to the brand... The result, Toyota, from #1 to #6...
The Service Provider features like BGP, OSPF, MPLS, BNG (PPP/DHCP) are the "Hero" features of RouterOS...
Chupaka
Fri Jun 08, 2018 1:07 pm
Well, sometimes those changes are simply not accepted into kernel :)
patrick7
Fri Jun 08, 2018 5:38 pm
2 years ago I had CCRs running in 3 locations. Now all CCRs have been replaced with debian+FRR boxes. Are much better (features, open source), and the price is +- the same.
The only mikrotik device I'm still using is a small CRS at home.
brotherdust
Fri Jun 08, 2018 10:15 pm
What it really boils down to is management decision to go where the money is. This is not unexpected or really all that surprising. Apple does the same thing. What's troubling is that they are effectively alienating some of their fiercest advocates, service providers, in the same way Apple is alienating their professional customers. From where I stand, it's a short-sighted and frustrating turn of events; especially since they aren't really communicating this change in strategy to their customers (maybe in shareholder meetings, but I'm not privy to those).
I think what angers me the most is they aren't willing to fess up and stop leading their service provider customers on with false hope of being able to deliver the features we need. I'm willing to be patient, to bend over backwards, but only if expectations are clearly communicated. If they can't deliver, they should explain why, and set new expectations. It's that simple. =/ Is that too much to ask?
brotherdust
Fri Jun 08, 2018 10:16 pm
That's a fair point. It's not a simple matter to get those changes accepted. But that begs the question: if they're being denied, why? Maybe write better code? =)
PtDragon
Sat Jun 09, 2018 6:23 pm
Dear MikroTik team!
Can we have some info on v7 progress?
Like "Release possible this year" or like "Release can be in next few years roughly" or "Don't even wait for it until 10-15 years".
You know in which state your code is, right?
And we still do not have any info at all so year after year we wait it blindly.
jarda
Sat Jun 09, 2018 6:29 pm
Why to wait for something that none knows anything about it?
jspool
Sat Jun 09, 2018 11:08 pm
I'm more excited that they are hiring Android & iOS programmers as well as mobile application WEB application programmers. Some native management apps would be very nice.
https://darbs.mikrotik.com/darbs/
When they are ready they will release the newer RouterOS. Their new building is more conducive to their growing needs and should allow them to evolve to the needs of the industries they serve.
jarda
Sun Jun 10, 2018 10:17 am
Unfortunately they are not seeking the persons they need the most: the security engineers.
z1022
Thu Jun 14, 2018 6:42 pm
We will release a beta, when it will exist. Currently v7 is in alpha stage, many functions are not completed and non functional. Beta needs at least all functions to be somewhat operational.
waiting for three year la
paoloaga
Wed Jun 20, 2018 6:34 pm
It seems that releasing a complete RouterOS v7 is a very complex task.
What if Mikrotik publishes new release branches? Something like:
Legacy-v5 - Stable-v6 - Current-v6 - Daily-v6 - Current-v7 - Daily-v7
V7 can be published starting with a minimal set of features. Who needs the complete set can install v6-current, who needs v7 features (like ipv6 recursive next hop) but doesn't need other things can optionally install v7.
Vooray
Wed Jun 20, 2018 11:43 pm
Hmm.. heared that U named company released linux 4 based firmware for their routers. Just to mention.
And, as i heared u can have frr on it.
No hands on that equipment, but i keep my eye on it.
And, as i track linux kernel changes, some descent work has been done in networking stack by guys from 6wind and cumulus.
So, mikrotik team, you have a chance. Or had?
huntermic
Wed Jul 04, 2018 4:01 pm
This makes me seriously thinking about goin back to this U named company, the lack of news on the great version 7 with support for 'old' thing like wave2 support and serious ipv6 support for instance. The Mikrotik hadware is capable but the software is limping on this hardware. Shame on Mikrotik for not even ging us an indication on how far development is. I'm done waiting.
pe1chl
Wed Jul 04, 2018 4:39 pm
The problem is that the U named company has so few options for routers, and so little router functionality in WiFi equipment.
huntermic
Wed Jul 04, 2018 5:30 pm
The real issue is lack of clarity. No communication or anything to keep us posted on the progress of the new kernel version. ( they call it version 7 but that's just a number ).
All they say is 'hey we have hardware that can do this, only the software can't but we will fix that in the next version, 7. But we might keep you waiting for many years'
ofer
Wed Jul 04, 2018 6:57 pm
from what I'm seeing from a business perspective there is no point pushing for the mythical v7 as long as the v6 still sells well
Mikrotik doesn't see v7 as a priority because v6 still sells.
when v6 will become a deterring factor we will see v7 being worked on seriously until that day comes don't expect to see any major investment in v7
you should all that this is the way things are v6 is available as is because there is no official word about v7 or future roadmap take that to consideration when buying Mikrotik products.
v7 the eternal alpha will be a unicorn until maintaining v6 will cost more than developing a new one
Sob
Wed Jul 04, 2018 7:58 pm
Except when v6 will become a deterring factor, it will be too late. It isn't easy to fix damaged reputation.
mistry7
Wed Jul 04, 2018 8:26 pm
the customers answer of missing features, don't buy it
mirhav
Thu Aug 23, 2018 1:51 pm
After these years, I do not expect any serious answers to come from the Mikrotik. .... Ubiquity is much more flexible in communication ... another region, another morality
alidamji
Sat Sep 29, 2018 7:12 pm
V7 beta seems to be already in development. You can see mrz's post:
viewtopic.php?t=130551
Seems to be v7beta running on Virtualbox.
buset1974
Sat Sep 29, 2018 7:49 pm
true endeed
joegoldman
Forum Veteran
Forum Veteran
Sun Sep 30, 2018 2:07 pm
I've been forced into ubiquiti for Wireless gear (PtMP Sector -> CPE networks), comfortably finding 27dbi, 29dbi dishes , 20+dbi sectors and a functioning proprietary high-speed AC protocol beat out Mikrotik systems - but FUCK ME if Ubiquity's management tools are absolute shit compared to Mikrotik / Winbox - talking purely over 500+ms links here my ubiquity web-portals are constantly timing out, where I can manage my RB1100's spread out over the same country fine (still use Mikrotik for routing and PPP termination).
wispmikrotik
Wed Jan 02, 2019 10:28 am
2019?
ofer
Wed Jan 02, 2019 10:57 am
2019?
Router OS v7 is never going to happen.
wispmikrotik
Wed Jan 02, 2019 8:29 pm
2019?
Well ... so let's get routeros v8.0.0 ...
:lol: :lol: :lol: :lol:
mrmut
Fri Jan 25, 2019 2:58 am
Maybe they will release v13 out of joke. :-)
Numbering doesn't matter, I am happy with them as it is.
Vitis
Fri Jan 25, 2019 11:12 am
Are you also happy with VRF implementation? :wink:
mrmut
Fri Jan 25, 2019 11:31 am
I had to google VRF to see what it is, so I guess the current implementation is just fine by me :-)
pe1chl
Fri Jan 25, 2019 11:41 am
Well today the numbering is usually enforced by marketeers and it could well be that a next release suddenly is called "2019" or whatever symbolic name.
But I agree that it is quite unlikely that we will ever see a version 7. There will undoubtedly be some creative move to work around that.
cgood
Sat Jan 26, 2019 12:28 pm
unsubscribe ...
enzain
Wed Jan 30, 2019 10:48 am
When?
We need multicore BGP (different peers connections on diffirent cores is minimum)
NAT64, DNS64, etc
Full OVPN support (compression, UDP)
etc.
enzain
Wed Jan 30, 2019 10:49 am
When?
Minimum - is multicore BGP
connorgoodwolf
Thu Feb 21, 2019 8:26 pm
Many are exceptionally disappointed at MikroTik's transparency on the release of RouterOS v7.0.
If MikroTik is unwilling to be transparent at the very least they could do is help RouterOS become Open Source so those who care about the platform can assist in development. Many of us have the skills needed and are willing to sign agreements with vendors to help push Mikrotik ahead.
Currently Mikrotik's lack of a roadmap, transparency, implementing standards like VXLAN which is documented by IETF in RFC 7348 is causing Mikrotik adoption to slow and companies are starting to choose competing products like ubiquity. Releasing new hardware isn't "helping" adoption, so please refrain from making statements like, "We're releasing new technology."
The ball is on your court MikroTik:
1) Choose to be transparent
2) Choose to work on Open Sourcing RouterOS
3) Continue the nose dive, destroy the company
normis
Fri Feb 22, 2019 2:12 pm
What do you mean? We have been very open about it.
V7 is not ready for public release, however, development continues. When it will be released? When it's stable enough. That's all.
Chupaka
Fri Feb 22, 2019 3:31 pm
"MikroTik. Destroying the company since 1999. For 20 years already." (c) :lol:
P.S. OMG! RouterOS is 20 years old this year?!? What's the exact date?
normis
Fri Feb 22, 2019 3:35 pm
Only RouterOS v2, but there was another one.
1995	Arnis and John start to provide Internet services to local businesses.
	Wireless network project in Moldova.
1996	SIA “Mikrotīkls” is incorporated. The name means “Small network” in the Latvian language.
1997	Starting work on a routing utility, which then is a MS-DOS program and is called “Tik” software system.
	PC routers based on 2.4GHz Aironet platforms IC2200.
1999	Installations in Kosovo and the first Linux based RouterOS v2.0
Chupaka
Fri Feb 22, 2019 4:52 pm
So, the first version of RouterOS was RouterOS 2.0, that's why I'm asking :)
boldsuck
Fri Feb 22, 2019 6:50 pm
Yes, then the Mikrotik hardware would finally openWRT friendly.
For our "Freifunk" projects in Germany, we mostly use / recommend AP's from Ubiquity or TP-Link. Every DAU can flash openWRT on it. Both companies are very community friendly. Sources per ftp downloadable. To send on CD as Mikrotik, is a nasty joke. ;-)
connorgoodwolf
Sun Feb 24, 2019 11:08 am
Can you please define the definition of transparency? I'll save you some time, "the quality or state of being transparent".
All you have told us since 2015 goes along the lines of "v7 is currently in internal testing, and will be released as beta when it's stable enough"
I don't like being direct, but what Mikrotik is doing to people who've spent years around Mikrotik hardware, certifications and dedication is wrong. You're hurting not only Mikrotik by not being transparent or forthcoming, you're hurting us.
Items YOU need to address:
1) A graph or document indicating the current status of RouterOS v7.0, even if the features are in flux.
2) Missing standards which will not be targeted in RouterOS v7.0, i.e. VXLAN
3) Update the community with facts and projections on current development
This whole situation would be made easier if Mikrotik had a developer program to work on an open source side project. It would not be hard to set up a lab, virtualization platform or real testing hardware for those who want to be serious about contributing.
normis
Mon Feb 25, 2019 10:40 am
Those are subjects to change. I don't want to promise anything and later tell you that we decided to remove something, or similar.
vecernik87
Forum Veteran
Forum Veteran
Mon Feb 25, 2019 11:44 pm
Hey guys, stop harassing Mikrotik about V7 :D It is a good topic for jokes but bad choice for serious discussion.
I am not a blind fan, but in this case, @normis is right. Anyone, who ever did a continuous development, knows that specifying future dates of release is a suicide. If you don't make it on time, everyone will complain (and it will be legit because promise was not delivered). If you rush it and make mistake/bug, everyone will complain (and it will be legit because even a simple bug can cost business millions).
Can't you be just happy that there are free updates which not only fix security holes but also improve functionality? And you can get all of that with device prices starting at $50?
In addition, demanding things this way is a bit ridiculous: "what mikrotik is doing ... is wrong" , "you need to address". Cmon... are you a shareholder or what? :lol:
Yeah. They flexibly told me that their products will misbehave if power is lost unexpectedly and the only solution is factory reset and restore from backup. Unfortunately I am stuck with them on three hospitality sites...
Sob
Tue Feb 26, 2019 4:32 am
I think the idea is that after years in development, it should be slowly shaping up and they should be getting some rough idea what it will contain and when it might come out. This very thread is four years old, and third post already mentions the "codename" unicorn. And that popped up only after some time of waiting, when people started to think that it maybe takes a little bit too long. And again, that was four years ago. I wanted to add "when I was still young", but it hasn't been that long, my chances to see RouterOS v7 are still good. :D
connorgoodwolf
Tue Feb 26, 2019 4:59 am
This is apart of the development process, many of us are the people who build complete platforms and architectures from the ground up. Even if a timeline or development status stated there was work on a specific feature which was later removed during a release then people would be enthralled there's at least some level of transparency.
Nobody is saying "promise us this," if you're working on an idea/feature/standard which doesn't make the cut then we may be a bit disappointed but it's better than "we're working on it"
connorgoodwolf
Tue Feb 26, 2019 5:02 am
All network equipment should have UPS units with AVR, to not have conditioning and backup power supplies attached to radio and networking equipment is asking for trouble.
zandhaas
Tue Feb 26, 2019 2:55 pm
Totally agree :!: :!:
telcouk
Tue Feb 26, 2019 4:31 pm
Without sounding harsh, I think you would have been better off not telling us about v7 if that's the case.
We would not have invested in Mikrotik kit and would have a fully working IPv6 setup by now.
normis
Tue Feb 26, 2019 4:53 pm
We have not advertised v7 as a version. The first post in this forum thread is by a user.
MikroTik only mentions v7 if there is some feature, that can't be implemented because of kernel limitations. In that case, it's technically not possible to make something until we have new kernel.
Other than that, have we told you there will be a v7 soon?
Sob
Tue Feb 26, 2019 6:06 pm
You didn't, but since the first time someone from MikroTik said "sorry, feature X is not possible now, it needs new kernel", the clock started ticking in users' heads. It's mix of optimism and trust, they (want to) believe that you want to give them the best and the right time for that is now, or at least soon. :)
Jotne
Tue Feb 26, 2019 6:12 pm
No??
Who created the subforum with the name RouterOS v6 RC and v7 BETA?? A user :)
telcouk
Tue Feb 26, 2019 6:21 pm
Just google, site:mum.mikrotik.com "v7"
Also what Jotne said.
#facepalm
connorgoodwolf
Tue Feb 26, 2019 6:34 pm
You know what would help fix this? Having an open source version of Mikrotik. Some of your users are the engineers who develop operating systems, have worked on various OSes including integrating code from KAME in to the BSD projects.
If there's a new kernel required, or a code in an existing kernel which needs to be modified, then perhaps this is the time to be transparent with the community.
Perhaps this is the time to engage the community and inquire if there's any interest in having a community driven project for Mikrotik hardware.
joegoldman
Forum Veteran
Forum Veteran
Wed Feb 27, 2019 12:28 am
The development going into 6.x is development FOR 7.x as well. A lot of the roadmapped features have been put into 6.x because of the delays 7.x brings. 7.x isnt going to suddenly have a heap of new features, 7.x will likely be the latest 6.x but on new kernel, and will take a few iterations to start getting new features that were otherwise impossible on the 6.x kernel - for instance my main feature request as of right now would be VRF aware management services and better VRF implementation over-all - my understanding is that this is a kernel limitation in 6.x, but i wont be expecting this feature in 7.0beta1, i'll probably not expect it till 7.5 or later, just because the first few iterations of 7.x will be just making sure everything runs as expected on new kernel.
Development is time. There's not an unlimited amount of developers working on this, and they are obviously still pumping out 6.x (230 odd changes/fixes in current changelog, massive!) so you just have to be patient - if you want massive company resources and promises, go spend massive dollars on Cisco/Juniper/whoever.
huntermic
Wed Feb 27, 2019 11:24 am
Fake News!
Sorry, this is the first thing that i think of when i read this crap.
You do sound a lot like Trump in this regard, you just can/will not tell the truth.
normis
Wed Feb 27, 2019 11:33 am
Sorry to break the news to some of you, but the official stance has always been - use v6. We are working on v7, and it will be released when it will be ready.
huntermic
Wed Feb 27, 2019 11:49 am
Correct, that indeed is the thing you keep telling us.
The problem we have is that for many years now you refer to this V7 and there even is a subforum called V7Beta, this raises expectations that after many years turn into frustration
normis
Wed Feb 27, 2019 11:56 am
I can repeat again, we only refer to v7 if there is something that can't be implemented in v6 due to kernel limitations. It doesn't even mean v7 exists.
mistry7
Wed Feb 27, 2019 12:00 pm
Developing on old Platforms often costs more ManPower then needed, there are so much changes in 4.xx Linux Kernel, why invest the time to back port them?
And it happend what i promise last year, Linux kernel is now at 5.00 and we don't see anything about ROS 7.......
We even don't know on that Kernel ROS 7 would be based.....but it would be outdated from the first day it released on....
huntermic
Wed Feb 27, 2019 12:07 pm
In that case, please do not say V7 but instead say: Some version we might release in the (probably distant) future
nescafe2002
Forum Veteran
Forum Veteran
Wed Feb 27, 2019 12:10 pm
Really?
huntermic
Wed Feb 27, 2019 12:12 pm
Really?
Why not, holds the same informational value: nothing
connorgoodwolf
Wed Feb 27, 2019 4:45 pm
ZERO TRANSPARENCY
normis
Wed Feb 27, 2019 4:46 pm
When is the new Tesla Y model coming out? What features will it have?
Which company, even the transparent ones, give you information about unreleased products?
connorgoodwolf
Wed Feb 27, 2019 4:51 pm
Elon has stated publicly the release of information about the model will come out around March 15.
When will we see a roadmap for v7?
connorgoodwolf
Wed Feb 27, 2019 4:52 pm
The current kernel needs quite a few modifications in order to accommodate much needed improvements.
normis
Wed Feb 27, 2019 4:55 pm
Before he said that. You didn't know about March 15, right?
OK so, please wait for a similar statement.
telcouk
Wed Feb 27, 2019 4:58 pm
We've been patiently waiting 5+ years :/
connorgoodwolf
Wed Feb 27, 2019 5:07 pm
How about you get the big boys at Mikrotik to the table so we can have an adult discussion?
You're only showing us how worthless the MikroTik training is since there is "no v7", no road map, nothing to show, no transparency and no engagement for the community who would gladly work on an community distribution (sort of like how people can load SwOS).
anav
Wed Feb 27, 2019 5:46 pm
@vecernik87
Wait, isnt this poster the magic unicorn? Even the magic unicorn doesn't know when v7beta will come out and thus we are all being treated equally. By the way buset1974 is obviously a student of software engineering and knows of what he speaks, the rest of you yahoos are smart as whips but on big picture stuff not really. Anyway, the real question is what will happen first, v7Beta released or a fricken stable version of Apex Legends.........
ofer
Wed Feb 27, 2019 9:15 pm
Same here I'm willing to join forces towards a community driven project.
patrick7
Wed Feb 27, 2019 9:16 pm
At least you can repair a broken tesla. But we can't repair RouterOS. BGP has been broken for 5+ years now and nobody knows when it will be fixed.
Oh, sorry, we do! It will be fixed with RouterOS v7 (tm)
connorgoodwolf
Wed Feb 27, 2019 9:25 pm
I'd be interested as well. A community driven firmware could push MikroTik back in to the limelight, but as right now they're falling to the way side.
Users browsing this forum: Aska, Google [Bot], loloski, mmackowiak, yoq and 182 guests
