azurtem
Trainer
Trainer
Mikrotik to Cisco IPSec VPN
Wed Sep 30, 2015 8:58 am
Hi
I replaced a customers Cisco ASA 5505 with a CCR1009
There were three IPSec VPN links which I implemented on the CCR1009 and everything is working fine
One thing I don't understand though is how to point to a VPN link
I need to add a route to guide traffic through one of the VPN links to the routeur that is situated at the other end of the VPN link
I tried creating a route indicating the remote router's local IP address as gateway but the CCR1009 isn't able to see it
Any ideas ?
thanks
yann
andriys
Re: Mikrotik to Cisco IPSec VPN
Wed Sep 30, 2015 3:57 pm
Classic (policy-based) IPsec does not take routing into account by design. IPsec policy is the only thing that determines which traffic gets encrypted and sent over the tunnel.
azurtem
Trainer
Trainer
Thu Oct 01, 2015 9:54 am
Thanks Andriys
We learn something new everyday
azurtem
Trainer
Trainer
Mon Oct 05, 2015 2:24 pm
Actually I still have a querstion regarding this issue
The LANs at either end can communicate with each other successfully
However I am unable to get the Mikrotik router, that is one end of the IPSec VPN tunnel, to route (dstnat) incoming (internet) traffic to the other end of the tunnel ?
thanks
yann
andriys
Tue Oct 06, 2015 10:21 am
If you still fighting the problem and is in need for help, please post your current config here.
azurtem
Trainer
Trainer
Wed Oct 07, 2015 10:49 am
thanks Andryis
I figured it out : the problem was that the incoming connection didn't belong to the LAN
therefore I had to create a srcnat rule to change the source address of the incoming connection
Users browsing this forum: andya, Google [Bot], wispvt and 176 guests
