tvrebac
Trainer
Trainer
Openssl CA certificate not recognized as CA
Mon Oct 12, 2015 12:23 am
I have problem with CA certificate generated by openssl not getting recognized by RouterOS (since version 6.28 and later) as CA.
The following command is used to generate CA:
openssl req -new -newkey rsa:2048 -config openssl_mikrotik-capsman_v1.cnf -keyout ca.key -out ca.crt -nodes -x509 -days 3650
I also tried to generate CA on RouterOS and it is recognized as CA cert. If I export that certificate and import it back it is not recognized as CA :-(
On RouterOS version 6.27 and earlier all works OK.
Does anybody know what is wrong with my setup or is it something wrong in the RouterOS?
Here is openssl_mikrotik-capsman_v1.cnf file (without comments)
RANDFILE		= ./.rnd
[ ca ]
default_ca	= CA_default
[ CA_default ]
dir		= .
certs		= $dir
crl_dir		= $dir
database	= $dir/index.txt
new_certs_dir	= $dir
certificate	= $dir/ca.crt
serial		= $dir/serial
crl		= $dir/crl.pem
private_key	= $dir/ca.key
RANDFILE	= $dir/.rand
x509_extensions	= basic_exts
crl_extensions	= crl_ext
default_days	= 3650
default_crl_days= 30
default_md	= sha256
policy		= policy_anything
[ policy_anything ]
countryName		= optional
stateOrProvinceName	= optional
localityName		= optional
organizationName	= optional
organizationalUnitName	= optional
commonName		= supplied
name			= optional
emailAddress		= optional
[ req ]
default_bits		= 2048
default_keyfile 	= privkey.pem
default_md		= sha256
distinguished_name	= req_distinguished_name
x509_extensions		= v3_ca
[ req_distinguished_name ]
countryName                    = Country Name (2 letter code)
countryName_default            = HR
countryName_min                = 2
countryName_max                = 2
stateOrProvinceName	       = State or Province Name (full name)
stateOrProvinceName_default    = PGZ
localityName                   = Locality Name (eg, city)
localityName_default           = Kastav
0.organizationName              = Organization Name (eg, company)
0.organizationName_default      = MyCompany d.o.o.
organizationalUnitName         = Organizational Unit Name (eg, section)
organizationalUnitName_default = CAPsMAN Test
commonName                     = Common Name (eg, YOUR name)
commonName_max                 = 64
emailAddress                   = Email Address
emailAddress_max               = 40
emailAddress_default           = pki@mycompany.lan
[ basic_exts ]
basicConstraints	= CA:FALSE
subjectKeyIdentifier	= hash
authorityKeyIdentifier	= keyid,issuer:always
[ v3_ca ]
subjectKeyIdentifier=hash
authorityKeyIdentifier=keyid:always,issuer:always
basicConstraints = CA:true
keyUsage = cRLSign, keyCertSign
[ crl_ext ]
AOEUMagnus
Re: Openssl CA certificate not recognized as CA
Tue Sep 13, 2016 10:42 am
A while after the question, but it can perhaps be of help to others.
You need to set nsComment="Generated by RouterOS" on the CA certificate to get the "A" (authority) flag when importing it.
tvrebac
Trainer
Trainer
Fri Jan 27, 2017 9:44 pm
I think I tried that too but didn't work. I also generated CA on the Routerboard itself, exported it, deleted CA, imported previous export and still didn't show A flag :-) Gonna have to test on newer bugfix releases and will post results.
Cheers!
tvrebac
Trainer
Trainer
Sat Mar 11, 2017 2:49 am
Yes, that is the solution of "problem" ;-)
OK, so config file needs to be altered, only [ v3_ca ] section is relevant here ...
[ v3_ca ]
nsComment = "Generated by RouterOS"
Thanx man!
mrz
Wed Mar 15, 2017 9:01 am
Why do you need A flag? Imported certificates work fine without it.
Only difference is that imported certificates cannot be used to issue new certificates .
luca1234567
Thu Mar 26, 2020 2:23 pm
I meet with this same problem of flag "Authority" of imported CA certificates in ROuterOS.
So i write this post viewtopic.php?f=2&t=159183
To request a correction of implementation.
Best regards.
Users browsing this forum: anav, Bing [Bot], forand, jamrobe, Kazek and 73 guests
