xunil76
jumper reset option staying disabled
Tue Oct 13, 2015 5:24 pm
i am trying to enable the reset jumper option in ROS 6.25 on an RB951G (firmware v3.19), and it will not stay enabled. i've tried both via the winbox option, as well as from command line (/system routerboard settings set enable-jumper-reset=yes), and it will not stay enabled.
when i set the option via winbox, the box will stay checked as long as my winbox session remains open, but as soon as i logout, then login again, it has disabled itself again (no, i am not using Safe Mode).
when i try to set the option via command line, it will not even enable the option.
the same thing is happening on 2 different RB951G's with the same ROS version and same firmware.
any reason this would be happening?
Users browsing this forum: InfraErik, ivankrosl and 124 guests
