MUM Europe 2020
mag
web-proxy and https
Sat Oct 02, 2004 11:55 am
is it possible to use the build-in web-proxy (2.8.16) for https-connections?
what would the ip firewall rule look like?
i tried:
 0   ;;; transparent http-proxy
     in-interface=lan dst-address=!192.168.254.0/23:80 protocol=tcp action=redirect to-dst-port=3128
 1 X ;;; transparent https-proxy - doesn't work!
     in-interface=lan dst-address=!192.168.254.0/23:443 protocol=tcp action=redirect to-dst-port=3128
(192.168.254.0/23 is my local network, where the proxy should be circumvented)
any hints?
matthias
lastguru
Trainer
Trainer
Mon Oct 04, 2004 3:27 pm
That should not work at all!
That is because of security inherent in HTTPS protocol - it just does not allow transparent proxying. Doing this would be considered a man-in-the-middle attack...
International MikroTik Certified Trainer and Consultant form Latvia.
I do RouterOS Training and Certification worldwide!
skype: lastguru
mag
Mon Oct 04, 2004 4:38 pm
yes, thanks.
i checked for the squid documentation also and there seems to be this "CONNECT" command, which is mentioned in the web-proxy docs too.
regards.
matthias
Users browsing this forum: nowinskit, PwFactor and 101 guests
