rwrocket
CCR1036 PPPoE & large 40mbit+ queues help/advice
Thu Oct 29, 2015 8:20 am
Currently I am running 6.32.2
I have long struggled with suspecting that queues in Mikrotik are slowing down my customers more than it should.
I thought I had solved the problem by going away from using the default-small queue type but I found the problem seems to be back.
Here is the scenario
PPPoE over VPLS tunnel running on MPLS over a reliable wireless link
PPPoE user has speed controlled by radius attribute
If I set the radius user to unlimited speed, I am able to reliably get 50+mbps
If I set the radius user to 40mbps download speed with default-small queue type I get max 30mbps
If I set the queue type to default I get max 37mbps
My Upload limit is 10mbps and works fine
I will continue to tweak my queue types in hopes to get this right but I am hoping someone else has found a reliable solution or queue size/type for high speed queues.
macgaiver
Re: CCR1036 PPPoE & large 40mbit+ queues help/advice
Thu Oct 29, 2015 9:36 am
What do you use? simple queues? queue tree? paste your queue config
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
rwrocket
Thu Oct 29, 2015 11:57 pm
As I said.....
PPPoE
this implies simple queue because as far as I know PPPoE can only use simple queues.
There is no queue config as such, they are created dynamically upon successful PPPoE radius auth
chechito
Fri Oct 30, 2015 2:24 am
y have noted that PCQ queues for high bandwidth need bigger buffer
rwrocket
Fri Oct 30, 2015 2:32 am
I have been having good success with wireless-default type actually in my recent tests
Hopefully it stays this way but looks like I may have found my solution
Users browsing this forum: e066377 and 137 guests
