onlineuser
utilization of CPU via WinBox
Fri Oct 30, 2015 6:38 pm
is there a way to see the utilization (CPU, memory,...) of my device via WinBox?
jarda
Sat Oct 31, 2015 7:27 pm
See tools - profile.
onlineuser
Re: utilization of CPU via WinBox
Sat Oct 31, 2015 9:11 pm
thx :-)
a more detailed profile would be nice ;-)
chechito
Sat Oct 31, 2015 9:30 pm
thx :-)
more detailed like what??
jarda
Sat Oct 31, 2015 11:40 pm
thx :-)
Right. It would be. Also similar tool for memory is missing.
onlineuser
Sun Nov 01, 2015 7:48 am
Ahhh, it's possible to add the memory, uptime, date, cpu via the WinBox dashboard.
But I am used to have a detailed overview from my DLink DFL firewall. There was one information site on which I could see several relevant data (cpu, connections, bandwidth, and so on).
jarda
Sun Nov 01, 2015 9:03 am
Well. The concept is different.
onlineuser
Sun Nov 01, 2015 10:41 am
I think it takes getting used to. ;-)
chechito
Sun Nov 01, 2015 6:53 pm
onlineuser
Sun Nov 01, 2015 8:28 pm
thx :-)
scampbell
Trainer
Trainer
Mon Nov 02, 2015 9:41 am
Also /tool graph where you can graph CPU and memory resources and traffic etc
onlineuser
Mon Nov 02, 2015 2:54 pm
chechito
Mon Nov 02, 2015 6:48 pm
onlineuser
Mon Nov 02, 2015 7:23 pm
Yeah, these graphs are nice but they need space on the internal file system.
When the storing to disk is disabled, will it be saved in memory?
What happens when the memory of my RB2011 gets quite full?
When 0.0.0.0/0 has access to the graphs I hope this setting does not override the firewall rules - if yes it would be bad - I will try. If I only want to see the graphs via WinBox this feature should be able to set up more specific.
onlineuser
Tue Nov 03, 2015 2:16 pm
When I activate the "storing on disk" in Graphing/Interface Rules or Ressource Rules, does the router save the data automatically on the stick instead of the internal memory?
I tried to log the interface statistics (without saving to disk). When will the logged data be removed? Although I deleted the rule I can see the loggin from the time when it was activated. Will it be gone when the router will be restarted?
jarda
Tue Nov 03, 2015 5:59 pm
The graphing data are stored to internal flash only and you cannot select the usb flash or memory card to store there instead.
onlineuser
Tue Nov 03, 2015 6:29 pm
thx :-(
The saving on external memory would be nice feature!
For what can be the external USB memory used?
jarda
Tue Nov 03, 2015 6:48 pm
It would. As you are asking the same things in more threads I already gave you the answer.
onlineuser
Tue Nov 03, 2015 6:51 pm
thx ;-)
Users browsing this forum: No registered users and 93 guests
