jmginer
How to select the gateway showed when you traceroute mi network?
Sat Oct 31, 2015 10:17 pm
Hello! I'm interested to select what IP to show when someone do a traceroute to some of my IPs.
I have a RouterOS install, working since a long time, with feel addresses. When it reboots, the "gateway" showed when I trace some of the IPs routed in this router is a randoom one. What I do to select the one that I want is to disable all addresses except the one that I want to show in traceroute, then, I enable all the others...
Now, I have installed a new router, and this trick not run... allways show the same gateway on traces.
What is the correct whay to select the gateway that I want to show when someone do a traceroute to some of my IPs ?
PS- Both routers are doing BGP.
Thanks a lot!!
Users browsing this forum: MSN [Bot] and 67 guests
