MUM Europe 2020
ik3umt
PCC load balancing : rules order and passtrough
Thu Nov 05, 2015 11:46 am
I'm using fine this mangle set for PCC loadbalancing
But "fine" doesn't always mean "the best way"
I was ask you about the rules sequence and the passthrough= statement are OK or not (there is some confusion in the moltitude of resources available on the net....)
ether1= LAN ether 6 = 192.168.10.2, ether 7 = 192.168.20.2, ether 8 = 192.168.30.2, (WAN)
192.168.10.1, 192.168.20.1, 192.168.30.1 = gateways
Thank you
0 chain=prerouting action=accept dst-address=192.168.10.0/24 in-interface=ether1
1 chain=prerouting action=accept dst-address=192.168.20.0/24 in-interface=ether1
2 chain=prerouting action=accept dst-address=192.168.30.0/24 in-interface=ether1
3 chain=input action=mark-connection new-connection-mark=WAN1_conn passthrough=yes in-interface=ether6
4 chain=input action=mark-connection new-connection-mark=WAN2_conn passthrough=yes in-interface=ether7
5 chain=input action=mark-connection new-connection-mark=WAN3_conn passthrough=yes in-interface=ether8
6 chain=output action=mark-routing new-routing-mark=to_WAN1 passthrough=no connection-mark=WAN1_conn
7 chain=output action=mark-routing new-routing-mark=to_WAN2 passthrough=no connection-mark=WAN2_conn
8 chain=output action=mark-routing new-routing-mark=to_WAN3 passthrough=no connection-mark=WAN3_conn
9 chain=prerouting action=mark-connection new-connection-mark=WAN1_conn passthrough=yes connection-state=new protocol=tcp dst-address-type=!local in-interface=ether1 dst-port=!443 per-connection-classifier=both-addresses-and-ports:3/0
10 chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes connection-state=new protocol=tcp dst-address-type=!local in-interface=ether1 dst-port=!443 per-connection-classifier=both-addresses-and-ports:3/1
11 chain=prerouting action=mark-connection new-connection-mark=WAN3_conn passthrough=yes connection-state=new protocol=tcp dst-address-type=!local in-interface=ether1 dst-port=!443 per-connection-classifier=both-addresses-and-ports:3/2
12 chain=prerouting action=mark-routing new-routing-mark=to_WAN1 passthrough=no in-interface=ether1 connection-mark=WAN1_conn
13 chain=prerouting action=mark-routing new-routing-mark=to_WAN2 passthrough=no in-interface=ether1 connection-mark=WAN2_conn
14 chain=prerouting action=mark-routing new-routing-mark=to_WAN3 passthrough=no in-interface=ether1 connection-mark=WAN3_conn log=no log-prefix=""
Users browsing this forum: pioccd and 106 guests
