49er
Problem with hopping from one AP to an other
Thu Nov 05, 2015 11:53 am
Hi, I have several RB951G-2HnD AP's in my network.
Now the problem is that I see that devices (not roaming devices but Static placed devices) are changing for one AP to an other AP frequently.
How can I reduce this?
Because of this problem the users are complaining about slow speed and sometimes losing connection for a sec.
nabas
Re: Problem with hopping from one AP to an other
Thu Nov 26, 2015 6:43 pm
Hi 49er,
I suggesto to reduce wifi aggressiveness on client side.
For deeper explanation look at http://www.hometoys.com/article/2012/04 ... akes/1812/.
The most import aspect is that "the roam trigger is completely client dependent".
nickshore
Thu Nov 26, 2015 7:30 pm
Use capsman and tunnel all traffic back to one router.
This reduces delays on switch between APs.
Nick
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
loveman
Fri Nov 27, 2015 7:55 am
Nick
Hello, has Cloud Core Router Board is a main, required to be a key link 4 Router Board so that all router change to 4 ACCESS Point to the original ,, if it has the main ip 192.168.1.0/24 so that each ACCESS dhcp take their point of main to any user "client" take ip from dhcp server "main router" to any one join in any 4 access point ,, What is the correct way to do
jarda
Fri Nov 27, 2015 11:28 am
Don't duplicate your post in multiple threads.
loveman
Re:
Fri Nov 27, 2015 2:05 pm
Initially commented here about the response by the Post for being written by his way .. and work of a special post .. Thank you for your interest
jarda
Fri Nov 27, 2015 6:04 pm
I already replied the same your post in other thread so I have found your posts duplicated. It is not necessary to ask the same thing multiple times at once.
loveman
Re:
Fri Nov 27, 2015 11:48 pm
Ok
Thank you
Users browsing this forum: No registered users and 96 guests
