ah3000
If Microtik Company Add This Two Options This Would Be Great
Fri Nov 13, 2015 10:28 pm
jarda
Fri Nov 20, 2015 5:05 pm
Isn't this task for firewall rules?
jarda
ah3000
Re: If Microtik Company Add This Two Options This Would Be Great
Sat Nov 21, 2015 11:33 pm
this two options can decide who can see server ip and mac address from win box
MTeeker
Sun Nov 22, 2015 6:21 am
I think it's more of device-centric issue, i.e. has to be done from the device which you want hidden. Otherwise, it's done via firewall rule as Jarda mentioned.
However, if it's a MikroTik router, you can disable its, say, gateway interface (under /ip neighbor discovery) to stop it from being discovered.
By design, it works both ways though, i.e. any neighbor routers can't be discovered from the hidden one either. I think.
ah3000
Sun Nov 22, 2015 6:11 pm
ok
but my idea any neighbor routers can't be discovered if ip renge 254 ip
by this Two Options i can allow to 1 or 2 o 3 or 4 users to discover router from 250 users
chechito
Sun Nov 22, 2015 9:25 pm
ok
usually equipment its managed from management networks not from user networks
Users browsing this forum: cypa, Google [Bot], ranveertbneha, wispmikrotik and 96 guests
