MUM Europe 2020
quochuy7610
Remote access by winbox anywhere
Wed Nov 18, 2015 7:18 pm
Dear All,
How to remote access by winbox anywhere (out site internet)!
Thanks,
jarda
Thu Nov 19, 2015 11:43 am
Accept inbound traffic to winbox port from outside. Of course you have public fixed ip as I expect.
docmarius
Re: Remote access by winbox anywhere
Thu Nov 19, 2015 5:13 pm
For added security I would recommend setting up a tunnel (pptp/l2tp/maybe even sstp) with proper firewall rules and then use local ip to access it.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
jarda
Thu Nov 19, 2015 5:59 pm
I can recommend the same but I am afraid that it is over the possibilities of the requestor.
quochuy7610
Fri Nov 20, 2015 7:37 pm
How to proper firewall rules and then use local ip to access it ? Now, i see neighbor list but I ping not OK (timeout)
freemannnn
Long time Member
Long time Member
Fri Nov 20, 2015 9:22 pm
also enable ip cloud so you have a free dynamic dns service from mikrotik. (if u dont have static ip of course )
docmarius
Sat Nov 21, 2015 12:55 am
Add following firewall filter rules (this should be the order):
1. allow access (input chain) from interface l2tp-out1 for icmp (to get ping if you like)
2. allow access (input chain) from interface l2tp-out1 for tcp port 8291 (to get winbox)
3. drop all input (input chain) from interface l2tp-out1 (for added security - optional - you can skip it for the moment)
cross
Sat Nov 21, 2015 10:59 am
Wow, I didn't know that mikrotik has such a service avalaible :)
So there's a lot of possibility. But the best is VPN or you can use Knock Port Rule in firewall. And then you will be able to "knock" yourself into mikrotik with any IP you want.
freemannnn
Long time Member
Long time Member
Sat Nov 21, 2015 3:22 pm
i like ip cloud and for me is working flawless. the only improvement i want is to be able to force-choose from which input wan connection will be updated, when u have multiple wan.
for example "force ip cloud" to always updates from wan1 connection (ether1) and routed by that connection always
Teno
Re:
Thu Dec 31, 2015 6:06 pm
Can I do this via ssh?
Thanks and Happy new year!
Users browsing this forum: No registered users and 94 guests
