sirtcp
RADIUS hotspot page 404 not found
Mon Dec 21, 2015 4:08 pm
i am using router board rb2011uiasI have never used RADIUS/user manager of Mikrotik before. however this time i want my Router board to run in dual mode. for office and for outsiders. i want to add outside users to come by UserManager / RADIUS and i control all official nodes by firewall.
now when i enable the RADIUS. it does show me error "Error 404: Not Found". i google the issue and found that if i change the port from 80 to something it will do the trick however it didn;t do the job. it still showing me same 404 error.
even double check the WWW service is running on 808 port and when i put my Mikrotik IP it also shows the control menu however when i add xx.xx.xx.xx/userman it shows the problem.
now i have two question how can i resolve it?
does that mean i can not use my routerboard as hostspot for outsiders and Accesspoint for official users togather?
Thanks,
Yousuf
ConnectivityEngineer
Re: RADIUS hotspot page 404 not found
Tue Dec 22, 2015 8:38 am
You should be able to do this - as long as a few things are in place.
1. If your using 2 different networks and place one in HotSpot mode - than only that network would require the hotspot...
2. Is the Radius Server authentication working?
What if anything is showing in the logs
Glenn Kelley | MCTNA, MTCWE, MTCTCE, RHCE, RHCSS
http://Connectivity.Engineer
USA Based 24x7x365 Mikrotik, Juniper, Ubiquiti TAC & WISP / ISP Blind Label Support Call Center
sirtcp
Tue Dec 22, 2015 11:37 am
Thanks for the tip i have now created a virtual wireless interface and assigned that to the hotspot. now i can connect and see the hotspot authentication page. now i have two SSIDs in one RouterOS firewall.
1 - one is for local LAN users Accesspoint.
2 - one for outsiders as hotspot.
now the problem part.
i still can not see the usermanager page.
it is still saying 404 not found.
i can reach hotspot login page working great.
WWW is using port 808
when i use xx.xx.xx.xx:808 it shows me my web console of the firewall which is also cool.
but when i xx.xx.xx.xx:808/userman then it shows 404 not found error.
this is how i created my radius.
/radius add service=hotspot address=10.x.x.1 secret=mypassword authentication-port=1812 accounting-port=1813 timeout=300 src-address=10.x.x.15
where address is my mikrotik firewall address and src-address is my station ip to access the 10.x.x.1:808/userman page.
any guidance would be highly appreciated.
Thanks,
Yousuf
sirtcp
Wed Dec 23, 2015 7:49 am
Any help will be highly appreciated. becuase i am banging my head for few days. i know i am doing some thing wrong and it is a one click matter but i am not reaching their. becuase everything from Hotspot login page to WWW services working fine except the userman page.
please help
Users browsing this forum: MSN [Bot] and 88 guests
