AlexS
CCR1036 and mirror ports
Tue Dec 22, 2015 9:45 am
Hi
Do I have any of this functionality under http://wiki.mikrotik.com/wiki/Manual:Sw ... _Mirroring
I am trying to setup a span port ... mirror all packets and send them to another interface.
becs
Re: CCR1036 and mirror ports
Tue Dec 22, 2015 10:14 am
CCR1036 router does not have any switch-chip therefore none of RouterOS commands in the RouterOS Switch menu work.
On CCR1036 similar functionality to port mirroring can be achieved by using a sniffer tool with configured streaming server.
http://wiki.mikrotik.com/wiki/Manual:To ... er#Example
ConnectivityEngineer
Tue Dec 22, 2015 10:16 am
If you add the port you wish to monitor to a bridge - and then add another port to the bridge the second port on the bridge will act like a mirrored port.
I know its a bit clunky - however since there are NO SWITCH CHIPS in the Cloud Core Router series - this is the work around if you need something wireline (ie running wireshark or similar on your desktop)
Becs solution above imho is a better option :-)
Glenn Kelley | MCTNA, MTCWE, MTCTCE, RHCE, RHCSS
http://Connectivity.Engineer
USA Based 24x7x365 Mikrotik, Juniper, Ubiquiti TAC & WISP / ISP Blind Label Support Call Center
robertkjonesjr
Wed Dec 23, 2015 2:19 am
It's not obvious why this would be so. Can you elaborate? If mac address learning was disabled somehow then yes - it would be a hub, not a bridge. Otherwise, unicast traffic should not be copied to this other port.
Users browsing this forum: Bing [Bot] and 89 guests
