hoboristi
crs125g and nas4free lacp not working
Sat Dec 26, 2015 3:49 pm
I have one hp microserver gen8 with nas4free embedded system, and configured lacp on it for the 2 gigabit ethernet nic, and also made it on the crs125g-1s-rm, created a bond with 2 interface and used L2 hash policy, but it is not working as expected. Uplink traffic is intermittend between 0 and 100 megabyte/s, downlink is stable 10 megabyte/s. It is very annoying behavior. Nas4free features are described there: http://www.zoonsweb.nl/wiki/doku.php?id ... r&s[]=lacp
cutedrummerboy
Re: crs125g and nas4free lacp not working
Wed Dec 30, 2015 4:32 am
You should use 802.3ad at both side. for me it works perfectly.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
hoboristi
Wed Jan 06, 2016 12:07 pm
How can I set up interfaces? The wrong config is:
two ports are in bonding, hash policy layer 2, other values also default (of course no master port)
bonding set to bridge1, what contains ether1-master (other ifaces has ether1-master as master port)
nas4free side bge0 and bge1 in lagg0, and lagg is set to lacp
hoboristi
Wed Jan 13, 2016 10:07 am
Anyone? :(
ZeroByte
Wed Jan 13, 2016 5:46 pm
CRS = slow for cpu-forwarded traffic. Bonding is cpu-forwarded traffic.
Use just one gigabit interface and it will go fast.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
hoboristi
Wed Jan 13, 2016 7:02 pm
:( well..but in that case, why is that device advertised as switch.. lacp is a basic function of managed switches
ZeroByte
Wed Jan 13, 2016 8:01 pm
... because it's certainly a switch. It does offer capabilities in the switch chip that other ROS devices don't have in their switch features (e.g. port isolation is in the CRS switch but not in a 2011).
Here is a wiki article about some examples of CRS capabilities:
http://wiki.mikrotik.com/wiki/Manual:CRS_examples
Perhaps the CRS can do LACP in the switch chip and I'm just not aware of it - check the CRS features manual page:
http://wiki.mikrotik.com/wiki/Manual:CRS_features
Apparently the methodology to get the full functionality from a CRS is different than the typical ROS methodology.
Good luck!
When given a spoon,
skuykend
Thu Jan 14, 2016 4:21 am
Pretty sure that currently the CRS switch chip's only supports static bonding in the switch, not LACP.
I believe the intent is to make them capable, but for some reason it doesn't seem to be a priority for Mikrotik yet.
Users browsing this forum: Bing [Bot], brixsat, Google [Bot] and 56 guests
