richinuk
CHR and max MTU
Tue Jan 12, 2016 6:07 am
Hi MT,
I couldn't find if this had been discussed already, but does the CHR fix the issue with large L2MTU? I know we had issues before CHR when using x86 RouterOS on ESX and MTU's above 1500. If so, what is the max MTU for CHR?
Rich
rwrocket
Re: CHR and max MTU
Wed Sep 21, 2016 7:18 am
*BUMP*
I would really like to know about this as I am using CHR on Unetlabs and I think I have ran into the MTU greater than 1500 problem
richinuk
Re: CHR and max MTU
Fri Oct 07, 2016 2:51 am
It works. I'm using on VMware and as long as you set the MTU on the VNIC to, say, 9000 then you can use large MTU's on the CHR guest.
Users browsing this forum: aacable, gangz, mbethers and 55 guests
