ariaking
Problem with Bridge on CRS125-24G-1S
Wed Jan 13, 2016 8:48 am
hi
in need help
when cables connect to Switch L2 every thing is very good and no Packet loss but when cable connected to CRS (all port Bridged) i have packet loss beetween local IP
I have 40Mb/s BW
thank you
when use switch
when use CRS bridge Port
scampbell
Trainer
Trainer
Re: Problem with Bridge on CRS125-24G-1S
Thu Jan 14, 2016 5:24 am
When ports are bridged all LAN traffic goes through the CPU (shared 1GB link) whereas when ports are switched LAN traffic does not impact the CPU so routing performance is better.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
fibernetwork
Thu Jan 14, 2016 10:14 am
"When ports are bridged all LAN traffic goes through the CPU (shared 1GB link) whereas when ports are switched LAN traffic does not impact the CPU so routing performance is better." agree with this answer.
Fiberstore -James
ariaking
Thu Jan 14, 2016 10:40 am
thank you
if i use Router high performance repeate this problem ? i need see and manage traffic for per interface
ariaking
Sat Jan 16, 2016 3:28 pm
No body ????
lambert
Long time Member
Long time Member
Sat Jan 16, 2016 9:13 pm
What about the traffic do you wish to "manage" per interface?
I suspect you can manage as well with the port in switch mode. This device, with all ports bridged, will likely pass around 100 - 200 Mbps of traffic, total. The CPU is not particularly powerful. You will likely be more happy with the results with switching enabled.
Have you watched the CPU utilization while you are bridged?
A CCR will pass more traffic if bridging or routing is required. With switching on the CRS, you will have many more ports capable of 1 Gbps.
ariaking
Sun Jan 17, 2016 8:22 pm
hi
im use master port and havent any problem :D
Users browsing this forum: MSN [Bot] and 78 guests
