Rick
Not enough disk space to perform update
Tue Jan 19, 2016 2:35 pm
Hi all,
I have a HAP lite, and am running version 6.33.3. I want to upgrade to 6.33.5 but get the error: ERROR: not enough disk space, 6.0MiB is required and only 1.6MiB is free
I am already stripped down to the basic packages, as you can see in this output:
system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 system 6.33.3
1 security 6.33.3
2 wireless-cm2 6.33.3
The 'Files' menu simply shows a backup and a autosupout.rif file, totalling less than 500KB together.
I read another thread that said the update was supposed to take place in RAM, however there was no solution to the OP issue, which appears to be the same as mine.
My System Resources:
system resource print
uptime: 1w3d13h47m5s
version: 6.33.3 (stable)
build-time: Dec/03/2015 16:08:10
free-memory: 8.6MiB
total-memory: 32.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 650MHz
cpu-load: 1%
free-hdd-space: 1640.0KiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 64939
write-sect-total: 72007
bad-blocks: 0%
architecture-name: smips
board-name: hAP lite
platform: MikroTik
What am I supposed to do here? I'd rather not have to do a netinstall each time.
Rick
Re: Not enough disk space to perform update
Wed Jan 27, 2016 2:47 pm
Any ideas?
Rick
Tue Feb 09, 2016 3:15 pm
Now the device has crashed as out of space, File List is empty, but all space is consumed.
I only have the following packages installed:
Security
System
Wireless
deanMKD1
Tue Feb 09, 2016 11:57 pm
As i know updating firmware goes in RAM, and Flash size is not important for updating firmware..
monkmartinez
Sun Jul 17, 2016 4:41 am
Same Error... looking for answers, again. I have not had a good experience with Mikrotik thus far.
barkas
Sun Jul 17, 2016 8:55 am
According to Normis, you have to use the other package download with individual packages and install those instead.
Pea
Sun Jul 17, 2016 9:46 am
It should be enough to do reboot and then update.
How much free-memory you have after reboot?
Anyway 8,6MiB visible in your export should be good for update.
ERge
Sat Aug 04, 2018 11:46 pm
Did you find a solution to the problem?
I have a similar problem.
I can not upgrade to version 6.42.6
He says: ERROR: not enough disk space, 7.1MiB is required and only 6.7MiB is free
How can I clean it?
Kindis
Sun Aug 05, 2018 11:54 am
How can I clean it?
Have you tried this?
https://www.mikrotik.com/download/share/fix_space.npk
You can read more on this at the forum post on 6.42.6
mobyj
Sun Aug 05, 2018 8:36 pm
How can I clean it?
i tried to install the fix space but cant enabled in packages after reboot
fragtion
Tue Sep 11, 2018 10:33 pm
It does not show as a package. Simply confirm if it worked by comparing Free HDD Space before and after rebooting with fix_space.npk
Brandon166
Fri Oct 05, 2018 11:01 am
Hello All,
I am experiencing the same issue.
All my mikrotiks are located remotely but cannot upgrade the Firmware as i don't have enough space.
Your assistance will be appreciated
konigman
Fri Nov 02, 2018 5:36 am
Having this issue as well. Anyone find any way to fix it?
Device: hAP lite (RouterBOARD 941-2nD)
Updating from: 6.42.7
Updating to: 6.43.4
Via: winbox packages update option
Result: log showing system error, "not enough space for upgrade"
I tried: clearing out files of basically everything and then rebooting. Showing 8.7MiB of 16.0 MiB used. No effect. Same system error.
Also noticed that Free Memory is 9.0MiB (out of total 32MiB). Isn't this too low for right after router reboot?
mkx
Fri Nov 02, 2018 12:52 pm
Depending on number of packages installed, but 8MB free space should be enough. However, the packagrs to be updated via system -> packages -> update are downloaded into RAM on units with small NAND and 9MB free memory does sound a bit tight. What you can try is to manually download needed packages and push them to the router via file upload functionality. When all needed packages are safely uploaded, do a reboot.
BR,
Metod
Muator
Fri Nov 02, 2018 2:32 pm
How can I clean it?
Please tell me where to get this link ?
Please tell me what makes the file downloaded from the link ?
Подскажите пожалуйста откуда взята эта ссылка ?
Подскажите пожалуйста что делает файл скачанный по ссылке ?
sawa
Fri Jul 19, 2019 7:42 pm
How can I clean it?
He does not do anything.
> sys rou pr
routerboard: yes
board-name: hAP mini
model: RouterBOARD 931-2nD
serial-number: ________
firmware-type: qca9531L
factory-firmware: 3.34.3
current-firmware: 6.45.1
upgrade-firmware: 6.45.1
> sys resource pr
uptime: 7m9s
version: 6.45.1 (stable)
build-time: Jun/27/2019 10:23:23
free-memory: 8.2MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-load: 13%
free-hdd-space: 7.5MiB
write-sect-since-reboot: 81
write-sect-total: 100111
bad-blocks: 0%
platform: MikroTik
> sys package update install
channel: stable
installed-version: 6.45.1
latest-version: 6.45.2
status: Downloaded, rebooting...
> log pr
23:36:06 system,info installed routeros-smips-6.45.2
23:36:06 system,error not enough space for upgrade
> file pr
# NAME TYPE SIZE CREATION-TIME
0 routeros-smips-6.45.2.npk package 7.4MiB jul/19/2019 23:35:58
Hmm, as we see absolutely nothing has changed. The bug stayed.
Users browsing this forum: andyh747, Google [Bot], oskarsk, rukverc, sparrow, vialli and 128 guests
