flameproof
NTP client in NTP package not working
Mon Jan 25, 2016 12:41 pm
Hi all,
On two CCR1012s, if I install the NTP package, the client side does not work - the time is set to January 10th (it's the 25th today) and the time is off by a few hours. If I disable the package and use SNTP instead, it syncs perfectly.
Any ideas? A forum search shows this coming up every now and then but no fix seems to happen.
hci
Long time Member
Long time Member
Re: NTP client in NTP package not working
Thu Jan 28, 2016 5:53 pm
What ROS version are you running? NTP client seems to have quit on one of our boxes when we moved too v6.33.5 on a CCR. It seems to have a few other issues too.
flameproof
Thu Jan 28, 2016 5:57 pm
It wasn't working on 6.33.3 and it's still not working on 6.33.5.
chronos
Wed May 11, 2016 9:05 pm
Also not working on 6.34.1 and 6.35. And we have two local ntp client -> ntp server proxies which both stopped to working. I don't know between which versions exactly. And we can't use SNTP as we need NTP server at the same time. I don't know how to solve this issue.
pe1chl
Thu May 12, 2016 1:14 am
I don't have this problem running 6.35.2 on a CCR-1009
I would advise you to trace the NTP traffic to see what might be the cause.
Users browsing this forum: chris72, eworm, Shqipalb and 78 guests
