spokke
ip routed
Mon Feb 15, 2016 4:21 pm
hi all...
i've a pppoe server and on same router another interface (call dmz) with static netmap (ex. 10.x.x.x facing to public a.b.c.d.) and all working fine .. the problem is that if i've access to a server in dmz network from a pppoe-client (with public ip) the ip accessing the server appear to be the gateway of interface dmz (like natted) ..
how can i make that access come from public ip ? thank you very much
lambert
Long time Member
Long time Member
Re: ip routed
Tue Feb 16, 2016 9:13 am
In your NAT settings, you might try adding an accept rule for src-address of pppoe interface IP range to dst-address of DMZ interface IP range. That will bypass the other NAT rules.
spokke
Re: ip routed
Tue Feb 16, 2016 9:38 am
resolved .. i've inserted a nat rule from a address list in which myip was listed :shock: :shock: :shock:
sorry and very thank
Users browsing this forum: No registered users and 125 guests
