vitorlins
Duplicate PPPoE client's
Sun Feb 21, 2016 2:16 am
Hi everyone, i have this issue with 6.33.3
lambert
Long time Member
Long time Member
Re: Duplicate PPPoE client's
Sun Feb 21, 2016 9:13 am
Different MAC addresses, different hosts. One PPPoE session per host. Not one PPPoE session per username.
Or maybe you want to explain your perceived issue more completely?
vitorlins
Tue Feb 23, 2016 5:00 am
In the profile I selected "only one", it should not be limited to only one User?
Trisc
Fri Feb 26, 2016 11:17 pm
I am also seeing this but with identical MAC adresses - v6.34.2
andersonlich
Mon Feb 29, 2016 3:14 pm
How do you assigned the IP address ppppe client? Is it from radius ?
If it's from radius, you need to work it from your radius.
I have experienced this issue, what I do is doubled checked from radius backend to SQL pool ip, if it's IP address has been used or not. When the backend radius to SQL slowed, this issue may be occured.
But the pool is from mikrotik itself. You need to check it to support.
I also want the mikrotik should disconnect the user if the IP address was duplicate.
vitorlins
Wed Mar 02, 2016 9:08 pm
The PPPoE client's are assign IP from Mikrotik IP POOL
Users browsing this forum: No registered users and 157 guests
