I'm trying to setup some VLAN networks on the CRS125 routerboard.
Routerboard generates all the vlan networks, there are no VLANs on the upstream.
I have created several VLANs on the master port and added the tags. Everything seems to work, but when many devices (ex. 30 laptops and cellphones, 150 devices total) try to connect over vlan, connectivity problem start to appear.
Windows shows "no connectivity" and amount of lost ping requests increases to 20%, ping time also increases.
I'm using UniFi AP-LR as endpoint AP for laptops and cellphones.
Could that be because of the misconfiguration? Can somebody check it?
Code: Select all
set [ find default-name=ether1 ] name=ether1-master
set [ find default-name=ether2 ] master-port=ether1-master
set [ find default-name=ether3 ] master-port=ether1-master
set [ find default-name=ether4 ] master-port=ether1-master
/interface vlan
add comment=K201 interface=ether1-master name=vlan2 vlan-id=2
add comment=K203 interface=ether1-master name=vlan3 vlan-id=3
add comment=STUDENTS interface=ether1-master name=vlan4 vlan-id=4
add comment=K205 interface=ether1-master name=vlan5 vlan-id=5
add comment=GUESTS interface=ether1-master name=vlan6 vlan-id=6
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether2,ether3,switch1-cpu vlan-id=4
add tagged-ports=ether2,switch1-cpu vlan-id=2
add tagged-ports=ether2,switch1-cpu vlan-id=3
add tagged-ports=ether2,switch1-cpu vlan-id=5
add tagged-ports=ether4,switch1-cpu vlan-id=6
add ports=ether1-master,ether2,ether3,ether4,switch1-cpu vlan-id=4
add ports=ether1-master,ether2,switch1-cpu vlan-id=2
add ports=ether1-master,ether2,switch1-cpu vlan-id=3
add ports=ether1-master,ether2,switch1-cpu vlan-id=5
add ports=ether4,switch1-cpu vlan-id=6
