littlebill
partitions
Wed Feb 24, 2016 6:22 am
i just learned what partitions are. yea i know noob.
question, is there a way to boot into a different partition, without winbox/cli/serial? if lock myself out how can i switch partitions?
also im assuming a netinstall will wipe the entire partition table and restart it from scratch?
jarda
Wed Feb 24, 2016 7:18 am
Power device on. Wait for a moment between booting of ros starts till it is not started yet. Unplug power. Plug power again and the second partition starts if it was set so... Using standard reset procedure you can get default admin login.
littlebill
Re: partitions
Wed Feb 24, 2016 5:26 pm
does creating a new partition cause an outage?
jarda
Wed Feb 24, 2016 6:59 pm
I guess a reboot is necessary for repartitioning the storage. The copy from live to backup partition is without reboot. But you should then boot to the second partition to test it. At least. So two reboots need to be expected. Try it in your lab first on non productive device to get familiar with it.
littlebill
Re: partitions
Wed Feb 24, 2016 7:45 pm
yea i will, do u know if netinstall wipes the entire partition table?
picacho99
Re: partitions
Wed Feb 24, 2016 9:24 pm
Yes it does.
And additionally just to advise you on RB3011: Partition does not work at all up to date (lasr RC tried too).
littlebill
Re: partitions
Wed Feb 24, 2016 9:39 pm
appreciate, sadly im looking at 961, which apparently shrunk the nand memory, but i have a 2011 to try it with
Users browsing this forum: lexart, Sob and 116 guests
