RichardD
LNS for PPP termination
Wed Feb 24, 2016 1:26 pm
I want to run a CCR1009-8G-1S as LNS for a CDMA network. Setup is like a typical PPP dial in szenario with l2tp tunnel between LAC (CDMA PDSN) and LNS by use of a radius server with framed-ip as radius attribute. It looks like, that I bring up the l2tp tunnel and succeed with chap. When we come to the IPCP phase we are running into the timeout of 30sec + 5sec and l2tp tunnel is closed by Mikrotik. I have setup similar szenarios with Cisco vpdn without a problem. Are there limitations at Mikrotik?
Thx in advance
Richard
RichardD
Re: LNS for PPP termination
Wed Feb 24, 2016 5:44 pm
To give you an idea about the Cisco setup:
vpdn-group <domain>
description xxx
accept-dialin
protocol l2tp
virtual-template 3
source-ip xxx.xxx.xxx.xxx
lcp renegotiation on-mismatch
interface Virtual-Template3
description TEMPLATE <domain>
ip unnumbered Loopback0
no logging event link-status
no peer default ip address
no snmp trap link-status
ppp authentication chap callin XX-RADIUS
ppp authorization XX-RADIUS
ppp accounting XX-RADIUS
ppp ipcp dns a.a.a.a b.b.b.b
Any idea how to realize with Mikrotik?
Thx Richard
richinuk
Thu Feb 25, 2016 6:08 am
Hi Richard,
I was actually just researching something similar and I came across this incase it's relevant to your issue: http://forum.mikrotik.com/viewtopic.php ... 98#p439892
Just thinking aloud - may not be related at all!
Rich
nz_monkey
Thu Feb 25, 2016 11:06 am
I can confirm.
RouterOS 6.35 has proper LNS support.
Specific features added are:
- PPPoE over L2TP
- Support for "outer tunnel" authentication (L2TP auth)
- Support for pre-auth on the LAC
It has been successfully tested against IOS and IOS-XE by us.
Once there is support for Radius VSA to put ppp connection in a VRF we will likely move from Cisco ASR as LNS to Mikrotik CCR
RichardD
Mon Feb 29, 2016 3:14 pm
thanks for the answers. We are not running PPPoE but PPP over L2TP. Is this supported as well by Mikrotik?
Thx
Richard
nz_monkey
Tue Mar 01, 2016 9:18 am
Thx
Richard
Hi Richard.
It sure is.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
phfsobhan
Thu Sep 29, 2016 4:36 pm
Thx in advance
Richard
Hi Richard,
We've the same scenario here, wondering if you succeed on MikroTik ?
odehneh
Fri May 12, 2017 7:32 am
We start using 1036 as LNS six months ago. Works fine. 800 Mbps for 25%CPU.
-- Omar
ganewbie
Fri May 12, 2017 3:05 pm
We are using LNS, PPPoE over L2TP tunnels, it works perfect and I recommend 6.39.1 as they have fixed couple of annpying bugs that was crashing some L2TP sessions in a special setup.
In our case Cisco is going out soon ;-)
Good job Mikrotik
nickshore
Fri May 12, 2017 4:39 pm
Can you post an example config for this ?
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
egjose
Sat Mar 03, 2018 7:09 pm
Anybody knows the configuration for previous scenario?
ntblade
Thu Jun 14, 2018 4:55 pm
Hi, anyone willing to post their configuration please?
NTB
Stevenhayes100
Tue Jun 26, 2018 11:47 am
I am also working on this as a project at the moment and would be greatful for any guidance :)
Thanks in advance !
Users browsing this forum: No registered users and 27 guests
