Splash
BGP Advertisments Table Missing Data
Fri Mar 11, 2016 9:59 am
When one removes the Router ID from the BGP Instance so that it uses the interface IP automatically, the Advertisements table becomes blank, however the routes are being distributed correctly.
In my case I am using 2 peers with the same same BGP Instance to distribute routes within a VRF. If I have 2 separate instances, it does not cross-distribute the routes even with the "Redistribute Other BGP" and the same Routing Table set.
When one instance is used it works fine, but when one disables the "Router ID" then there are no routes advertised within the table.
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
Users browsing this forum: MSN [Bot] and 71 guests
