Duduhandelman
FastTrack without NAT
Sun Mar 20, 2016 1:36 pm
Hi All,
Is that possible to use FastTrack over bridge without NAT?
I'm unable to get it working with 6.32.4 counters remain zero on the dummy rule and ip settings. while fastrack rule and normal rule has the same counter.
Thank you,
jarda
Sun Mar 20, 2016 5:17 pm
There should be fastpath working on the bridge where ip firewall is not enabled.
http://wiki.mikrotik.com/wiki/Manual:Fa ... ge_handler
Duduhandelman
Re: FastTrack without NAT
Sun Mar 20, 2016 6:45 pm
Thanks Jarda.
You are correct. I thought that i will be able to bypass everything for my voip data and queue all the other data.
I'm missing something here.
Maybe fasttrack is not working without routing.
Duduhandelman
Mon Mar 21, 2016 4:42 pm
Now I took it to the lab with the latest 6.35 rc34.
Fasttrack will not work on bridges....
I hope it's on the roadmap.
macgaiver
Mon Mar 21, 2016 4:49 pm
FastPath work with bridges with no problems as long bridge ports support fastpath also.
This is both for bridging and for routing fastpath.
As you are talking about fasttrack, i assume you have routing setup with some firewall rules.
It works fine.
Other option i can think of is that you are talking about bridging fastpath ,but with use-ip-firewall enabled.
if you enabled "use-ip-firewall" fastpath is not possible.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Duduhandelman
Mon Mar 21, 2016 5:00 pm
Thanks Macgaiver.
You are correct I'm using bridge with firewall only for QOS I wanted to give my voip users better service.
Again,,
amt
Long time Member
Long time Member
Sat Jun 17, 2017 9:50 am
which is better for using bridged network ? using use ip firewall yes at bridge settings and activate fasttrack or using fastpath ?
Duduhandelman
Sat Jun 17, 2017 10:04 am
AMT.
As far as i know there is no firewall while using fastpath. And fasttrack is not working without nat.
So if you are using just a bridge and need performance use no firewall with fastpath.
Use a switch instead.
amt
Long time Member
Long time Member
Sat Jun 17, 2017 10:52 am
Thanks Duduhandelman....
Cha0s
Forum Veteran
Forum Veteran
Sat Jun 17, 2017 4:06 pm
You you have any documentation references on that?
I don't see anything here https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
I use FastTrack without NAT and it works fine AFAICT.
amt
Long time Member
Long time Member
Mon Jun 19, 2017 10:23 am
Im using bridged network and on many device fasttrack notworking. if I enable use ip firewall on, it seems start to work.
Users browsing this forum: robsgax and 88 guests
