At completely (seems) random intervals all the peers and instances settings disappear, and bgp sessions of course stop working.
The RB is still responsive and i can telnet to it from the neighbour, and a simple /routing bgp peer print solves the situation.
First time /routing bgp peer print shows nothing , a second /routing bgp peer print show all the peers again and the sessions come back up.
Code: Select all
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 2.9.29 (c) 1999-2006 http://www.mikrotik.com/
Terminal vt102 detected, using multiline input mode
[admin@aim] > /routing bgp peer prin
Flags: X - disabled
Flags: X - disabled
0 name="peer1" instance=default remote-address=80.79.50.10 remote-as=65001
tcp-md5-key="" nexthop-choice=force-self multihop=no route-reflect=no
hold-time=3m ttl=1 in-filter="" out-filter=""
1 name="peer2" instance=aim-local remote-address=80.79.50.1 remote-as=34695
hold-time=3m ttl=1 in-filter=infracom out-filter=""
2 name="aim2" instance=default remote-address=80.79.50.22 remote-as=65051
[admin@aim] >
A quick hack is to run a scheduled job that runs a /routing bgp peer print every some minutes.
The problem shows up with 2.9.27 , 2.9.28 and 2.9.29
What can i do to help you solve the problem?
Ideally the scheduled scripts should avoid keeping the sessions stuck, and the problem seems not to show on lab.
I can send either configuration files, or a supout.
I can also turn bgp debugging on.
Bye,
Ricky
