azurtem
Trainer
Trainer
Bricked wAP following 6.32.4 upgrade
Wed Apr 20, 2016 4:47 pm
Hi
I purchased a few wAP (RBwAP2nDr2) and have begun deploying a couple.
I configured them and then upgraded them to 6.32.4 (System & advanced tools & Wireless-cm2)
Now they are bricked: un-rea-cha-ble
The LEDs come on, and then a few seconds later, switch off, and then back on, etc...
I tried a reset but this has no effect whatsoever
Tried the same thing with two more wAPs, same result, except that now I have four bricked wAPs, (ed. well six now !)
I tried to reinstall the original ROS (6.30.4) via NetInstall - but without success so far
So basically, the gist here is don't upgrade (or downgrade) a wAP if you know what's good for you
Any ideas on how to fix this mess ?
thanks
yann
pukkita
Trainer
Trainer
Re: Bricked wAP following 6.32.4 upgrade
Wed Apr 20, 2016 5:00 pm
Netinstall using 6.34.4
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
azurtem
Trainer
Trainer
Wed Apr 20, 2016 9:34 pm
OK, I finally managed to reinstate 6.30.4 using Netinstall
Apparently Netinstall doesn't behave properly on Win7-64 or WinX-64
I booted up with Hiren 15.2 and was able to successfully install the desired ROS
and now the wAP is back in action
Sorry for the confusion my post may have caused
rextended
Wed Apr 20, 2016 10:31 pm
I do not have XP at 64 bit, but on windows 7 sp1 64 bit, windows 8.1 64 bit and windows 10 netinstall work without any problem only if the only active interface are the interface used for programming the device.
I'm Italian, not English. Sorry for my imperfect grammar.
azurtem
Trainer
Trainer
Thu Apr 21, 2016 4:21 am
Thanks RExtended
Hiren contains an XP Pro 2002 (32bit)
I did try to upgrade the wAP from 6.30.4 to 6.32.4 through the file copy approach and it still didn't succeed
Still, this isn't very practical if Netinstall is the only available solution to upgrade ROS on a wAP
pukkita
Trainer
Trainer
Thu Apr 21, 2016 2:04 pm
It is not... I have a wAP and I upgraded it using both the drag n drop .npk and System > Packages Upgrade without problems.
There was a hiccup on 6.35rc versions that may cause this, but doesn't seem to be the case here.
Good practice to avoid this:
- Keep firmware updated
- Reset it to no defaults after major upgrades (reload the configuration afterwards)
azurtem
Trainer
Trainer
Thu Apr 21, 2016 7:09 pm
Thanks Pukkita
Even Martin said that this isn't an issue.
As I said earlier all I did was upgrade these wAPs from Winbox 3.4 and the
drag & drop method with the three 6.32.4 modules and obtained the same
result with each one.
I even tried this again once I had recovered the devices thanks to Netinstall
and got the same result
So either I'm really unlucky i.e. bad batch, or else I don't know :]]
Well the important thing, as I told Martin, is that I found a work around
and that everything is hunky dory again.
I guess I won't be updating them any time soon, that's for sure.
Thanks for your inputs
cheers
azurtem
Trainer
Trainer
Fri Apr 22, 2016 8:06 pm
Well the wAPs weren't operating properly on the client's network (CAPsMAN v2)
The connection would constantly come and go
So I tried to upgrade them to 6.35: this was successful, what do you know !
Not sure what the lesson is here...
Users browsing this forum: bpwl, DL7JP, Google [Bot], McSee and 209 guests
