akliouev
Incorrect reporting of IPSec installed SAs
Thu Apr 21, 2016 11:25 am
Greetings!
I noticed that both Winbox and Webmin do report incorrectly the IPSec installed SA's properties.
Here's some examples:
Winbox report of installed SAs and details about a particular SA. Please note that the encryption algorithm is empty while the key is present:
Webmin's report of the installed SAs. Same problem -- the encryption algorithm is empty for both the list and detailed report of an SA:
But the /ip ipsec installed-sa pr report seems to be reporting the encryption algorithm correctly as aes-gcm:
[admin@XXXXXX_MikroTik] /ip ipsec installed-sa> pr
Flags: A - AH, E - ESP
 0 E spi=0xCC9D8F5 src-address= dst-address=yyy.yyy.yyy.yyy
     state=mature enc-algorithm=aes-gcm
     enc-key="secretrandomkeysecretrandomkeysecretrandomkeysecretrand1"
     addtime=apr/21/2016 10:05:26 expires-in=9m20s add-lifetime=16m/20m
     current-bytes=198146 replay=128
 1 E spi=0xE0E6563 src-address=yyy.yyy.yyy.yyy dst-address=xxx.xxx.xxx.xxx
     enc-key="secretrandomkeysecretrandomkeysecretrandomkeysecretrand2"
     current-bytes=144972 replay=128
 2 E spi=0x47259A7 src-address=xxx.xxx.xxx.xxx dst-address=yyy.yyy.yyy.yyy
     enc-key="secretrandomkeysecretrandomkeysecretrandomkeysecretrand3"
     addtime=apr/21/2016 10:07:05 expires-in=10m59s add-lifetime=16m/20m
     current-bytes=861034 replay=128
 3 E spi=0xDFDC0D2 src-address=yyy.yyy.yyy.yyy dst-address=xxx.xxx.xxx.xxx
     enc-key="secretrandomkeysecretrandomkeysecretrandomkeysecretrand4"
Is this normal or I'm missing something the the configs?
Regards,
Alex
Users browsing this forum: Google [Bot], krafg, yaikun94 and 149 guests
