GuJack20
Trainer
Trainer
IP on a Vmware ESXi dedi
Sat Apr 23, 2016 10:52 pm
Hello
I installed RouterOS in a virtual machine in a Vmware ESXi.
I have the ip 62.x.x.x for the virtual machine. The ISP tech says that i must configure this ip 62.x.x.x with subnet mask /32 and to give as a gateway the main ip of the server but ending with 1. i.e. My server's main ip is 178.x.x.100, than the gateway of mikrotik RouterOS would be 178.x.x.1.
Such config works ok in windows hosts, but with MikroTik i get "No route to host", since the 178.x.x.1 is outside of the 62.x.x.x subnet.
How can i solve this?
Thanks guys
--Do you remember that guy who gave up? Neither does anybody else!
Sob
Re: IP on a Vmware ESXi dedi
Sat Apr 23, 2016 11:46 pm
RouterOS does it like this:
add address=62.x.x.x network=178.x.x.1 interface=<interface>
Edit: That was just point to point addresses, second step is the actual route:
add distance=1 gateway=178.x.x.1
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
GuJack20
Trainer
Trainer
Sun Apr 24, 2016 12:03 am
Yeah, right. I didn't know that.
It works
Thanks bro
GuJack20
Trainer
Trainer
It works
Thanks bro
Users browsing this forum: No registered users and 80 guests
