basd
Filter DNS any request to our Nameservers
Mon Apr 25, 2016 9:35 pm
I am currently experiancing DDos attacks to our name server.
They are using DNS amplifaction attacks to Request any record from our DNS server.
On the linux name server's i can filter it like this :
$IPTABLES -A INPUT -p udp --dport 53 -m string --hex-string "|00ff|" --algo bm --from 40 -j DROP -m comment --comment 'Block ANY requests'
$IPTABLES -A INPUT -p tcp --dport 53 -m string --hex-string "|00ff|" --algo bm --from 40 -j DROP -m comment --comment 'Block ANY requests'
Can i do the same with in our microtik router ?
We have 2 ccr1036-12G-45 routers.
With kind regards,
Bas van den Dikkenberg
With kind regards,
jarda
Mon Apr 25, 2016 10:23 pm
add action=drop chain=input connection-state=new dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=input connection-state=new dst-port=53 in-interface=ether1 protocol=tcp
Just use your wan interface instead ether1. Looks like you should think about your firewall more deeply, closing this doesn't close other holes you probably have there.
And last thing: using Google you'd have the answer long time ago,especially when the most topics here are about the same again and again .
basd
Re:
Mon Apr 25, 2016 10:26 pm
This no solution this way you block all trafic en not only the ANY request .
With kind regards,
Sob
Re: Filter DNS any request to our Nameservers
Tue Apr 26, 2016 12:37 am
There's L7 matcher, but it does not like null bytes. You could use bare FF, but I'd be affraid there could be some false positives:
/ip firewall layer7-protocol
add name="dns ANY" regexp="\\xff"
add action=log chain=forward dst-port=53 layer7-protocol="dns ANY" protocol=udp
On the other hand, FF should probably not appear in question section, so if you manage to skip "dangerous parts", namely id, it might work fine:
add name="dns ANY" regexp="...*\\xff"
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
ZeroByte
Tue Apr 26, 2016 1:38 am
The correct solution in Linux is to set bind to only allow recursive queries from your approved networks:
Example in /etc/bind/named.conf.options:
acl "MyDNSclients" {
  192.168.0.0/16;
  x.x.x.0/24;
  x.x.y.0/24;
  x.x.z.0/24;
  x.x.q.0/22;
  etc...
options {
 // stuff...
 allow-query {"MyDNSclients"; };
 // more stuff...
Simply blocking DNS Amplification destinations in IPtables while you're being used as an amplifier is like trying to kill flies with a hammer after you've forgotten to take out the garbage for too long. You need to close the door and maybe keep blocking streams for a while until the botnets learn that you're now refusing queries.
As for Mikrotik - you really need to just block all sources that you don't want to give DNS service to - use an address list:
/ip firewall address-list
add list=MyDNSclients address=192.168.0.0/16
add list=MyDNSclients address=x.x.x.0/24
etc...
and then in the filters:
add chain=input protocol=udp dst-port=53 src-address-list=MyDNSclients action=accept
add chain=input action=drop comment="default drop all packets"
(and don't allow DNS queries from any other source)
When given a spoon,
you should not cling to your fork.
The soup will get cold.
pe1chl
Tue Apr 26, 2016 10:53 am
He probably has an authoritative DNS server for a domain running behind a MikroTik router.
So it should be able to process queries from all over the world.
Due to the slackness of internet providers worldwide in implementing source address filtering (IMHO any ISP
that does not implement BCP 38 should be kicked off the internet!) he is receiving queries to his DNS server
with spoofed address, these result in larger replies that are sent to the faked source address, saturating his
own and the victim's bandwidth.
A stopgap is to disallow "-t ANY" queries because those have the largest amplification in size from request to
reply. However, the only real solution is the extermination of source address spoofing in the internet.
basd
Tue Apr 26, 2016 12:44 pm
Correct we are running authoritative DNS servers.
Your are correct but how to find the source
With kind regards,
pe1chl
Tue Apr 26, 2016 3:13 pm
Yes that is the big problem, as long as there are lousy internet providers we are stuck with this problem.
I run a /16 network on internet, you can image how much crap it receives.
I am not an expert on MikroTik L7 filters, but I suggest to apply the filter to the DNS server itself for now,
so at least it does not reply. Maybe some expert can suggest a working filter for MikroTik later.
Users browsing this forum: ivanfm, sistelec and 52 guests
