PROBLEM:
1. PC1 and PC2 can go Internet but
can't ping each other
When I traceroute ping from PC1 to PC2. PC1 traffic goes to internet not thru PC2 gw 192.168.0.129
2. PC1 can't ping 192.168.0.1
PC2 can't ping 192.168.0.129
What's wrong with my steps
tq
INFO
WAN
# export
/queue simple
add max-limit=128k/128k name=128k target=ether2
add max-limit=256k/256k name=256k target=ether3
add address=13.13.13.1/30 interface=ether2 network=13.13.13.0
add address=23.23.23.1/30 interface=ether3 network=23.23.23.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add action=masquerade chain=srcnat src-address=13.13.13.0/30
add action=masquerade chain=srcnat src-address=23.23.23.0/30
R1
# export
add name=dhcp_pool1 ranges=192.168.0.21-192.168.0.125
add name=dhcp_pool2 ranges=192.168.0.131-192.168.0.235
add address-pool=dhcp_pool1 disabled=no interface=ether3 name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=ether4 name=dhcp2
add address=13.13.13.2/30 interface=ether1 network=13.13.13.0
add address=23.23.23.2/30 interface=ether2 network=23.23.23.0
add address=192.168.0.1/25 interface=ether3 network=192.168.0.0
add address=192.168.0.129/25 interface=ether4 network=192.168.0.128
/ip dhcp-client
add address=192.168.0.0/25 dns-server=8.8.8.8 gateway=192.168.0.1
add address=192.168.0.128/25 dns-server=8.8.8.8 gateway=192.168.0.129
/ip firewall mangle
add action=mark-routing chain=prerouting in-interface=ether3 new-routing-mark=ISP1
add action=mark-routing chain=prerouting in-interface=ether4 new-routing-mark=ISP2
add action=masquerade chain=srcnat out-interface=ether2
add check-gateway=ping distance=11 gateway=13.13.13.1 routing-mark=ISP1
add check-gateway=ping distance=12 gateway=23.23.23.1 routing-mark=ISP1
add check-gateway=ping distance=11 gateway=23.23.23.1 routing-mark=ISP2
add check-gateway=ping distance=12 gateway=13.13.13.1 routing-mark=ISP2
add distance=11 gateway=13.13.13.1
add distance=11 gateway=23.23.23.1
/system identity
set name=R1
PC1
# export
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether3
/system identity
set name=PC1
PC2
# export
/ip dhcp-client
/system identity
set name=PC2
