Freman
Manipulation
Fri Oct 08, 2004 9:49 am
Is there any way to manipulate strings with mikrotik scripting?
IE: I've got "192.168.0.8/32" as a string from /ip firewall mangle src-address but now I want to compare it with /ip address (use it with /ip address find address=$xx)
So I'm looking to strip the /32 from it...
Ideas?
edzix
Fri Oct 08, 2004 10:09 am
you will be able to manipulate with strings in version 2.9. In currently supported RouterOS version it's not possible, but maybe you can try to use preferred-source parameter which could be found under '/ip route' menu.
Edgars
Freman
Fri Oct 08, 2004 10:29 am
Ah, thanks, yes I'm positive that will work just as well...
Ok folks, here you go, a script to add and remove ip's from mangle that checks to see if it needs to add/remove before adding/removing
Wack it in an interval job and it can check for comming and going of people
AddToMangle
:foreach i in=[interface find type=pppoe-in] do= {
:foreach n in=[/ip address find interface=$i] do={
:global a;  :set a[/ip address get $n network];
:put ("Checking on " . $a . "/32")
:if ([/ip firewall mangle find src-address=($a . "/32")]="") do={
 /ip firewall mangle add src-address=($a . "/32") p2p=all-p2p action=passthrough mark-flow=p2p-out comment=$a
 /ip firewall mangle add dst-address=($a . "/32") p2p=all-p2p action=passthrough mark-flow=p2p-in comment=$a
RemoveFromMangle
:foreach i in=[/ip firewall mangle find mark-flow=p2p-out] do= {
:global a;  :set a [/ip firewall mangle get $i src-address];
:log message=("Checking on " . $a )
:if ([/ip route find dst-address=$a]="") do={
:foreach n in=[/ip firewall mangle find dst-address=$a] do={
/ip firewall mangle remove $n
 /ip firewall mangle remove $i
edzix
Fri Oct 08, 2004 10:36 am
can you please post it in form taken from '/system script edit <script name> source'?
Edgars
Freman
Fri Oct 08, 2004 3:11 pm
Sure, first thing monday morning, unless I have an excuse to return to the office between now and then
I just used winbox to write them, you pretty much just go to system->scripting + give the script a name, and paste the code in
Users browsing this forum: asam, Baidu [Spider], Bing [Bot], brg3466, emitosolini, raffav and 203 guests
