cutedrummerboy
ipv6 auto configuration (SLAAC) question
Tue May 17, 2016 1:06 pm
ipv6 auto configuration (SLAAC) is not providing my router lan interface global ip as gateway to my client (win7, debian jassie, miui android, win10). it is providing the link local ip of my router lan interface as gateway. is it correct for auto configuration?? can any one tell me why this is happening??
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
cutedrummerboy
Re: ipv6 auto configuration (SLAAC) question
Tue May 17, 2016 4:25 pm
one more question, can anyone tell me when the full version of dhcp6 will release??
pe1chl
Tue May 17, 2016 7:25 pm
How did you configure that address on the interface?
Make sure you have all addresses configured on the correct interface and no bridge between them.
cutedrummerboy
Tue May 17, 2016 7:37 pm
[admin@ISP1 Router] /ipv6 address> print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     FROM-POOL INTERFACE        ADVERTISE
 0  G fd50:15fc:9a22:2::1/64                                vlan2        yes
 1  G fd50:15fc:9a22:4::1/64                                vlan4        yes
 2  G fd50:15fc:9a22:5::1/64                                vlan5        yes
 3  G fd50:15fc:9a22:6::1/64                                vlan6        yes
 4  G fd50:15fc:9a22::2/64                                  ether1        no
 5 DL fe80::d6ca:6dff:fe91:5cc8/64                          ether1        no
 6 DL fe80::d6ca:6dff:fe91:5cc9/64                          vlan4        no
 7 DL fe80::d6ca:6dff:fe91:5cc9/64                          bonding1        no
 8 DL fe80::d6ca:6dff:fe91:5cc9/64                          vlan2        no
 9 DL fe80::d6ca:6dff:fe91:5cc9/64                          vlan6        no
10 DL fe80::d6ca:6dff:fe91:5cc9/64                          vlan5        no
here is my addresses. ether1 is connected to another router
ZeroByte
Wed May 18, 2016 12:13 am
It is normal that devices will use the link-local address as the gateway. In general, when devices talk to other devices on the same LAN segment, they're going to use the link-local addresses and not the globally-unique routable addresses (public addresses). It takes a little getting used to, but it makes sense when you start to get the hang of it.
Also - the router isn't providing the address, it's advertising the local prefix. It's the client device which chooses an address for itself from within the prefix of the advertisement. Routers send the RA messages using their link-local addresses, and the client device will simply set its default gateway to be the link-local address of the router whose advertisement it heard.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
cutedrummerboy
Wed May 18, 2016 6:41 am
thank you ZeroByte, i understand the fact. i think now its time to get full support for dhcp6 in routeros. also we need separate package named ipv4 and no need of separate ipv6 package.
Users browsing this forum: danmiles86 and 78 guests
