ICEASYCOM
routing-test issue, support silent
Fri Sep 15, 2006 10:39 am
We have problem with ospf. When we enable routing-test package, routers have 100% utilization of CPU(RB112 completely die), When we enable standard routing package routers works very good. In /ip route we have about 700-800 routes(we have pppoe). Problem is on the every version of MT (on the latest too). I sent suppout.rif file (31.08.2006) to the support but I don't have any answer. Does anybody have the same problem as me ?? Its very big problem for us, because we have many mikrotiks(legal!!!!!!) and when routing die, our clients are furious :roll:
nabuk
Fri Sep 15, 2006 10:46 am
We have routing filter that doesn't work..........more then 600 /32 route not filtered !!
Also 2.9.30 will ignore framed-route radius attribute
sten
Forum Veteran
Forum Veteran
Re: routing-test issue, support silent
Fri Sep 15, 2006 6:50 pm
dude, running routing daemons on an RB112? Are you kidding me?
Dynamic routing protocols on end user equipment! That's something that will keep hurting, again and again.
Dynamic routing protocols are synonymous with memory-hogs.
The route table requiring memory is bad, but the information on what is going to be put in the routing table is even worse. The routing daemons need to keep everything just to feed the route table with a small selection.
Stick to default routing on edge and keep dynamic routing to the core network. (Core vs. distribution vs. access networks)
Move along. Nothing to see here.
sten
Forum Veteran
Forum Veteran
Fri Sep 15, 2006 6:55 pm
600 /32 routes? Which routing protocol are you using? RIP or BGP?
Framed-route bug is serious, it prevents us from using that version.
blabla
Fri Sep 15, 2006 9:11 pm
This was just example of the CPU utilization problem with routing-test.
We have just bought 5 of them for tests, and everyting that is needed to RB112 die is just enable OSPF on it and connect to the network :)
ICEASYCOM
Sat Sep 16, 2006 11:44 am
sten, so what mikrotik team is produce this version of routerboard(112 is shit for my at this time) ??? this can't work with any of dynamic routing protocols ?? as AP or APC i can buy ovislink, planet, etc. in this sittuation, but i have mikrotik, I pay and I WANT! When I pay for RB or MT, i think that I pay for SUPPORT, too!
Beccara
Long time Member
Long time Member
Sat Sep 16, 2006 12:32 pm
Using BGP/OSPF on a 112 is just plain stupid - they are 175mhz cpu's designed to be CPE side. Nstream with PPP* and some firewall stuff.
It was never meant to be a AP or router as is clearly shown with a single ether port.
Even using a rb532 with Nstream anf BGP/OSPF would be pushing it
ICEASYCOM
Sat Sep 16, 2006 5:26 pm
OK, but I writed on my first post about problem with routing-test (high utilization of CPU - x86, too). RB112 was as example. I writed on the forum, because I don't have any answer(standard) from support. Standard routing package is good, but routing-test do 100% utilization of CPU(celeron, pentium 4, AMD, which have many GHz).
Beccara
Long time Member
Long time Member
Sun Sep 17, 2006 2:06 am
100% CPU is not a bad thing, it shows the system is working. Leave it for an hour or so to get the initial routing stuff out of the way and it should drop
Mapik
Sun Sep 17, 2006 3:15 pm
We are using OSPF and the same problem from 2.9.28 to "now" :( IN filters OK, but OUT filtering is broken, after reboot all routes go out :-\
ICEASYCOM
Sun Sep 17, 2006 11:58 pm
yes, You have a right, but when routers have 100% CPU routing die, LAN don't work correctly. On a few seconds www and etc. don't work. I think that routing-test have some bugs, so I writed on the forum. Standard routing package work rather correctly(in my opinion).
Users browsing this forum: benoitc, ncats, rafaelwzs, Znevna and 116 guests
