ascharein
Missing packages for RB3011
Thu May 26, 2016 4:19 pm
In the all_packages-arm-6.35.1.zip for the RB3011 I am missing the user manager package and the lte package.
Maybe the lte package is missing for hardware or kernel incompatibilities, but the user manager is hardware independent.
Why the user manager is missing? Without user manager i can't migrate from RB2011 to RB3011.
Pans
Re: Missing packages for RB3011
Tue Mar 14, 2017 6:57 pm
Problem is still presence, why no one is answer?
pukkita
Trainer
Trainer
Tue Mar 14, 2017 7:20 pm
A search would have brought up there's no user-manager for ARM architecture.
user-manager may work directly with hardware, but it needs to be compiled for ARM architecture, so it is hardware dependent.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Pans
Tue Mar 14, 2017 8:43 pm
But what with lte package?
pukkita
Trainer
Trainer
Tue Mar 14, 2017 8:51 pm
Probably same reason, no support for ARM architecture yet. Are you using a mini pcie LTE modem?
Pans
Tue Mar 14, 2017 11:15 pm
No, I'm using usb lte modem (huawei e3372), and actually router detect modem, but it impossible to save username\password\APN. Each time after closing window all fields are empty. And everytime status only 'running'
matiaszon
Wed Mar 15, 2017 1:11 am
Is your modem E3372 working in HiLink mode? If so, there is no matter what you set up in LTE settings... Everything for connection is being set up in modem web interface.
pukkita
Trainer
Trainer
Wed Mar 15, 2017 11:45 am
Pans: as matiaszon pointed, you don't need LTE support in your scenario. You can consider it as another, standalone network device.
Depending on your modem firmware, you can use it either by setting a DHCP client, or a PPPoE client on the 3011.
Most modem parameters should be set on the modem itself using a serial connection and AT commands or modem web interface if provided, and stored on modem memory afterwards.
Pans
Wed Mar 15, 2017 12:44 pm
Thanks for all, as you said there is no need in this package, everything work fine, just need change dhcp client, and update firewall rules to new wan interface
matiaszon
Fri Mar 17, 2017 5:02 pm
You can configure DMZ on MikroTik's IP (most probably to an address from 192.168.8.0/24 range), and then set up routing on MikroTik. However, you will have 2 NATs then, but for home purposes you won't notice.
Users browsing this forum: No registered users and 142 guests
