azurtem
Trainer
Trainer
CCR1009-8G-1S-1S+ compatible MicroSD or USB
Thu Jun 09, 2016 1:53 pm
Hi
I'd like to enable the web proxy on this device in order to log user browsing data
I'd like to use a compatible (flash device) MicroSD or USB key that has enough space to handle this
I don't think there would be a great difference in speed between MicroSD or a USB key; am I right ?
I purchased a MicroSDHC SanDisk Extreme Plus 16 GB, Class 10, U3 but this doesn't appear in the system disk list of devices
Could you suggest a manufacturer and model that you have already successfully used ?
thanks
yann
azurtem
Trainer
Trainer
Re: CCR1009-8G-1S-1S+ compatible MicroSD or USB
Fri Jun 10, 2016 9:40 am
We have tested various vendor microSD cards and they all have worked fine, however
the tested cards mostly were micro SDHC type therefore we recommend those. But on
CCR1009 writing speed is far more better for USB port than microSD slot, so if you
plan to use extra storage for web proxy, in the end I would recommend to use USB
flash for it and leave microSD for logging storage or something else.
Regards,
Janis B.
Users browsing this forum: Bing [Bot], Google Feedfetcher, JensHD, markos222, sindy and 61 guests
