DDDD
PPPoE problem
Sat Sep 23, 2006 12:55 pm
I've set adsl modem recently.
Every seemed to be fine - PPPoE client is up/running, masquarading is set.
Then I noticed that a lot of sites didn't work (among them HTTPS sites).
I don't get what's wrong with it.
I've tried to use WebProxy, same problem.
Can anyone help me to solve it?
I know that th answer is on the surface, but I can't see it.
thanx in advance
marko_bg
Sat Sep 23, 2006 2:31 pm
try set:
MTU=1492
MRU=1492
DDDD
Sat Sep 23, 2006 5:27 pm
Doesn't work. (
I've tried to set IP Proxy, it helps. I guess all work only when connection is initiated by mikrotik.
Could it be that ISP doesn't support forward or smth like that?
Stryker777
Sat Sep 23, 2006 6:20 pm
If your Mikrotik is connecting to your dsl via PPPoE have you tried modding your tcpmss in the mangle table? If not try this:
/ip firewall mangle add chain=forward protocol=tcp tcp-flags=syn action=change-mss new-mss=1452 comment="Syn MSS to 1452" disabled=no
marko_bg
Sat Sep 23, 2006 6:26 pm
ask your provider for MTU and MRU setting
DDDD
Sun Sep 24, 2006 2:07 pm
Helped. thanx a lot.
Users browsing this forum: Google [Bot], MSN [Bot] and 92 guests
