David1234
how to make the unit reboot in script?
Thu Aug 04, 2016 3:38 pm
Hello ,
I'm want to write a script that in the end of it - will reset the unit
but it doesn't do it
when I run the script in the terminal , everything is working until this part:
are you sure (y\n)?
how do I tell him to ignore this and reset the unit anyway ?
the script end with
/system reboot;
Thanks,
BlackVS
Re: how to make the unit reboot in script?
Thu Aug 04, 2016 9:00 pm
If I remember right it won't ask anything if run in script.
I've just tested - created simple script with one line "/system reboot;" and run it from Scripts List -> Scripts window - router rebooted.
I.e. "Y/n" is asked only when running from terminal...
scampbell
Trainer
Trainer
Fri Aug 05, 2016 2:17 am
I concur with BlackVS.
We often create a scheduler to reboot router at midnight with just "/system reboot" as the only command - it works well and is only "interactive" when run from a console.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
cutedrummerboy
Fri Aug 05, 2016 5:41 pm
yeah if you write a script with only /system reboot and run it it will reboot the router.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
Users browsing this forum: Baidu [Spider], Google [Bot], Guntis, Kindis, matiss, Znevna and 127 guests
