MUM Europe 2020
pedja
Long time Member
Long time Member
Limiting access by signal level?
Fri Sep 29, 2006 3:56 pm
I noticed that most of open AP's have problems with unknown clients that connect to AP but have too low signal for normal operation. That causes problems to others connected to the same AP.
It came to my mind idea that it would be great if we could set AP to simply refuse connections fromclients which do not have required signal level.
I guess technically that is possible if MT can measure received signal level of each wireless client.
BrianHiggins
Long time Member
Long time Member
Sun Oct 01, 2006 8:08 pm
this would be cool, but not essential. you could duplicate this feature with some scripting if you really wanted it.
dorijan
Mon Oct 02, 2006 10:26 pm
I think you can do this in 2.9.x withous any script
you just define in connect list minimal signal strenght...
savagedavid
Trainer
Trainer
Tue Dec 05, 2006 10:59 pm
beta 3 has this feature in the access list
noam_chom
Re: Limiting access by signal level?
Sun Aug 26, 2007 11:35 pm
This could be excelent feature, I don't know why noone from mt haven't answered or proposed an alternative solution to this. Using a script is not a solution since the problem would be allready made till the script detect the level of the client signal strength.
Using access list is not an option for a public hotspot.
I tried to solve the problem setting ack timeout to static value (e.g. 385) , I've got some improvements, but ack timeout is not the right solution to this.
cmit
Mon Aug 27, 2007 11:01 am
Why not?
I think that would be the perfect (and only!) solution to this. Just configure the access-list to deny association to clients with a signal strength below -80 (or whatever you like).
This would work for a public hot-spot, too. You would not have to allow every MAC address, if you think of that...
Best regards,
Christian Meis
noam_chom
Mon Aug 27, 2007 10:20 pm
Why not?
Best regards,
Christian Meis
:-) It didn't occurred to me that the access list could be used with just the signal-strength parameter, and yes you are right that could be solution in 3.0 > versions.
But the problem still exists in the 2.9.45. I am using 3.0rc1 for testing purposes only on one of my RB532's but it still got some issues.
So I am stuck with the problem for now I suppose.
Best wishes,
Ilija
janisk
Tue Aug 28, 2007 1:12 pm
tehn check you rc3 and see if you still have problems, if you do, create supout.rif and send it to support@mikrotik.com
Users browsing this forum: CZFan, MSN [Bot], nescafe2002 and 104 guests
