kemerovo
IPTV
Fri Aug 19, 2016 7:24 am
our network of 25 computers and 1 console ror IPTV
startup problems begin consoles
winbox does not respond, router rebooted by watchdog, user user SQL not respond
when will it work? Why should I put multiple routers for normal ??
I will write about this problem EVERY DAY until you decide to choose.
I'm tired of these network problems.
п.с.
может банить менять хоть милион раз, я все равно найду способ сюда зайти, прокси никто не отменял
jarda
Re: IPTV
Fri Aug 19, 2016 7:30 am
I am afraid you haven't described any problem, just that the router was rebooted by the watchdog. It could be even correct, none knows how you have set it.
kemerovo
Re: IPTV
Fri Aug 19, 2016 7:55 am
supout.rif send 16/05/2016
Ticket#2016051666000086
Chupaka
Re: IPTV
Wed Aug 24, 2016 1:47 am
we don't have access to your conversations with Support :)
it's community forum, we are just people like you. if you need an answer from support - write to support@mikrotik.com
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
kemerovo
Re: IPTV
Thu Aug 25, 2016 5:26 am
I do not need your advice , I need an official response , when there will be the realization of a normal iptv
docmarius
Re: IPTV
Sat Aug 27, 2016 4:32 pm
Then why do you post to the forum?
And do you think it is somehow our fault, and we have to hear about your issues every day?
Write to support, not here. As said, this is an user forum.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
kemerovo
Re: IPTV
Tue Aug 30, 2016 11:56 am
if reading my posts , you would see that the support staff does not respond to them
kemerovo
Re: IPTV
Tue Aug 30, 2016 11:58 am
helpdesk, instead of helping to block my ip adress in this forum
docmarius
Re: IPTV
Tue Aug 30, 2016 8:18 pm
And this makes it OK to threat us with post flooding? Please think again.
This is an issue between you and Mikrotik, not with us.
If you need user help, other users may be glad to offer it. If not, don't post, that is your choice, but refrain from dragging us in your war on this forum.
kemerovo
Re: IPTV
Wed Aug 31, 2016 5:05 am
at the moment I do not see help users and answer mikrotik
BartoszP
Re: IPTV
Wed Aug 31, 2016 7:49 am
At the moment we read complaints of the grumbler. If you want help from us just ask for it.
Real admins use real keyboards.
kemerovo
Re: IPTV
Wed Aug 31, 2016 4:40 pm
nobody forces you to read it
normis
Re: IPTV
Wed Aug 31, 2016 4:44 pm
2016051666000086 ticket was answered.
The email says that we don't have IGMP snooping and that we may work on it in future.
That's an official response.
kemerovo
Re: IPTV
Thu Sep 01, 2016 8:24 am
... and that we may work on it in future.
and more concrete? in a year, two? or three?
jarda
Re: IPTV
Thu Sep 01, 2016 8:46 am
In these cases is official answer always the same: when it will be then it will be. If you are not willing to wait, obtain devices of other manufacturers that are you sure will provide whole set of features you need.
kemerovo
Re: IPTV
Thu Sep 01, 2016 9:43 am
there are exceptions in all of rules, therefore I ask to do an exception and name exemplary terms though
mrz
Re: IPTV
Thu Sep 01, 2016 2:27 pm
As It was determined in other topics you created, you don't even need feature you are requesting. IGMP snooping is for switches, but you are trying to route Multicast streams over your router, in this case IGMP-proxy should be used which RouterOS already supports.
3bs
Re: IPTV
Thu Sep 01, 2016 3:15 pm
mikroik routers don't have switch processors?
WBR, 3bs =)
mrz
Re: IPTV
Thu Sep 01, 2016 3:23 pm
what is the point of the question?
BartoszP
Re: IPTV
Thu Sep 01, 2016 3:27 pm
Thay do have. Why are you asking ? Are you suprised that router is not all-in-one solution ?
If the lownmower has an engine it does not implies that it could be used as a car.
3bs
Re: IPTV
Thu Sep 01, 2016 3:41 pm
You use linux kernel that support this feature, customers needed this featre, but you ignore feature requests. :)
WBR, 3bs =)
kemerovo
Re: IPTV
Thu Sep 01, 2016 3:47 pm
OK, if you do not need it , give me the settings for normal operation iptv
instead of empty words would be better to add a function that you are asking users have one year
mrz
Re: IPTV
Thu Sep 01, 2016 3:51 pm
As far as I remember information already was provided and you already started to use it?
Here are the configuration example again
http://wiki.mikrotik.com/wiki/Manual:Ro ... y#Examples
kemerovo
Re: IPTV
Thu Sep 01, 2016 4:12 pm
the flow goes on all ports , the CPU load is increased to 80 , the router crashes , filtering does not help
mrz
Re: IPTV
Thu Sep 01, 2016 4:30 pm
Open a new ticket with support with attached supout file after the crash. And simply do not mention anything about igmp snooping in that mail :)
kemerovo
Re: IPTV
Fri Sep 02, 2016 4:43 am
sent, Ticket#2016090222000151
docmarius
Re: IPTV
Sat Sep 03, 2016 9:27 pm
It surely goes to all ports, since you have one master port and the other slaves.
Filtering does not work on slave ports, only on masters, so your filter rules do not work as expected.
If you really want filters, get all ports out of the switch, use them individually, put them in a bridge and filter at bridge level.
This is the only solution for the moment. But you will be limited by your CPU and the fact that there is a bottleneck between switch and CPU.
Alternatively, you could put your console on a separate subnet/interface if it is directly connected to the router.
kemerovo
Re: IPTV
Mon Sep 05, 2016 4:35 am
ok, thank you, describe please more detailed as it to do, it is possible the personal report
if will I filter multicastes for example on 3, 4 port, and there will be 20 clients on wi fi, all 20 a stream will go again??
mrz
Re: IPTV
Mon Sep 05, 2016 10:36 am
When you disable switch configuration and add all slave ports to the bridge, then igmp-proxy should send multicast streams only on those bridge ports where client, that joined the multicast group, is connected. So bridge filters are not needed.
kemerovo
Re: IPTV
Mon Sep 05, 2016 11:39 am
once again
mrz
Re: IPTV
Mon Sep 05, 2016 11:47 am
If you filter multicast on port 3,4 then of course it will not go to clients connected to those ports. It's not exactly clear what you want to set up and why you need those filters.
kemerovo
Re: IPTV
Mon Sep 05, 2016 12:03 pm
if is a question not quite clear you, why you write an answer??
look http://forum.mikrotik.com/viewtopic.php?t=62073
and a problem is in that is needed that multicastes clients got only starting pleer, but not all in succession clients which are limited the use of one interface
kemerovo
Re: IPTV
Mon Sep 05, 2016 12:05 pm
can there be petition will accelerate a process and adequate answers for the questions of users???
BartoszP
Re: IPTV
Mon Sep 05, 2016 12:15 pm
Maybe the question is poorly asked ? Docmarius has clearly explained why in his opinion your filters for eth3 and eth4 do not work.
P.S.
OK. There is no IGMP snooping ... we need to live with that fact ... if it is such a problem you can always change yor router or read this http://www.snbforums.com/threads/mikrot ... ing.30356/
kemerovo
Re: IPTV
Mon Sep 05, 2016 12:34 pm
read a post # 32
did I read your reference, tuning I did not find there, for what you it it was copied me???
ps
it is unnecessary to pretend to be whatever you understood, you all had understood, limitation a multicaste will give nothing, will correct a problem only igmp snoping
BartoszP
Re: IPTV
Mon Sep 05, 2016 1:16 pm
And what .... ? Do you think that beeing quite rude will help to resolve problem ?
Mikrotik has no IGMP snooping ... if you want to rosolve your problem you have to try other solutions.
Why I have cited you ? As your English is not perfect and you accuse others that they do not understand what you write to them. You seem to be quite bombastic at the moment.
P.S.
My English is also far from beeing perfect ... I know this ...
P.P.S.
п.с.
Do not scare us ... I do understand Russian
RudeBoy
Re: IPTV
Mon Sep 05, 2016 3:13 pm
A. Please .... focus on your own problem and do not start stupid flame war without reason.
B. PLEASE DO NOT call me "клоун" in public. There is no reason to do that.
C. Please do not use Russian ... it is forum in English language.
1. If you do not have an answer on the question , save yourself from writing messages PLEASE)))))))
BartoszP
Re: IPTV
Mon Sep 05, 2016 3:28 pm
Great the first post ... I will wait for next one ...
normis
Re: IPTV
Mon Sep 05, 2016 3:39 pm
kemerovo, Mrz is trying to help you.
Answer the questions please, maybe issue will get solved.
BartoszP
Re: IPTV
Mon Sep 05, 2016 3:49 pm
Normis ... seems that RudeBoy is the reincarnation of Kemerovo as Kemerovo is "on vacation" to calm his nerves.
RudeBoy
Re: IPTV
Mon Sep 05, 2016 4:02 pm
OK. write questions on the list , I will reply to all , on the - in my opinion I have long been explained on the official forum and mail
BartoszP
Re: IPTV
Mon Sep 05, 2016 4:48 pm
RudeBoy has decided to NOT BE forum user. I do not why but after 1.5 h of his registration on the forum I have been negatively rated as:
Very gently speaking: Cosmic fool.
Chupaka
Re: IPTV
Mon Sep 05, 2016 5:24 pm
kids are so kids...
jarda
Re: IPTV
Mon Sep 05, 2016 5:30 pm
... While BartoszP has decided to be a sheriff, judge and the prison principal of this forum in one person. Very promising but I am starting to be afraid a bit of it. Nothing personal or against, just I would not be so radical...
mrz
Re: IPTV
Mon Sep 05, 2016 5:39 pm
If you read my one of the previous posts it states that when switch config is removed and slave ports are added as bridge ports then igmp proxy will do the same as igmp snooping - only ports where clients, that joined multicast group, will receive the stream.
BartoszP
Re: IPTV
Mon Sep 05, 2016 5:49 pm
Jarda. Have you translated this comment to "not gently" version ? Aren't you impressed that it has taken him 1.5h to write such comment ? Do you say "hello cosmic idiots" to welcome all when you go to the meeting ?
P.S.
I have not decided to be a prison cook .... yet :-) :-)
RudeBoy
Re: IPTV
Mon Sep 05, 2016 5:50 pm
example - 3 port is connected to 10 computers via a switch, 10 is connected via Wi Fi, and other interfaces are not involved. multicast needs on two computers which are connected to 3 port and one is connected via Wi Fi.question-multicast will receive 1 compuetr for Wi Fi and all 3 port or something different?
mrz
Re: IPTV
Mon Sep 05, 2016 5:58 pm
Multicast stream will be sent only to the client which have joined the multicast group.
RudeBoy
Re: IPTV
Mon Sep 05, 2016 6:01 pm
well, that's what I need.describe, in detail, how to configure my router
mrz
Re: IPTV
Mon Sep 05, 2016 6:04 pm
Remove switch configuration
/interface ethernet set [find] master-port=none
And then add each ethernet to bridge ports (except WAN port of course).
RudeBoy
Re: IPTV
Mon Sep 05, 2016 6:08 pm
it is possible to send a screenshot?
jarda
Re: RE: Re: IPTV
Mon Sep 05, 2016 7:33 pm
P.S.
I understood your opinion for the first time yet. And I mostly agree with you. But anyway shouldn't we take this topic out of this thread and create a separate discussion about the crime and punishment?
mrz
Re: IPTV
Tue Sep 06, 2016 3:24 pm
How to add bridge ports?
You can find an example in the manual
http://wiki.mikrotik.com/wiki/Manual:In ... #Example_2
RudeBoy
Re: IPTV
Tue Sep 06, 2016 4:32 pm
did your settings, nothing has changed
normis
Re: IPTV
Tue Sep 06, 2016 4:40 pm
Post your full config now, so that somebody can check it.
RudeBoy
Re: IPTV
Tue Sep 06, 2016 5:27 pm
I send supout.rif in support mail
Ololoev
Re: IPTV
Thu Sep 08, 2016 4:18 am
when the problem will be solved?
jarda
Re: IPTV
Thu Sep 08, 2016 12:00 pm
This is user experience forum. It is not clear whether you have misconfigured your device or whether there is real problem. If you do not publish your full config, we cannot help you. If you insist on error and you are able to proove it, you need to communicate with support via e-mail.
Ololoev
Re: IPTV
Thu Sep 08, 2016 4:38 pm
e-mail I wrote many times, you do not answer
jarda
Re: IPTV
Thu Sep 08, 2016 6:23 pm
I do not have to answer. I have no relation to mikrotik support, I am the same poor user like you. My experience with support is quite good, they are trying to answer within a week or so. Be patient, you will get an answer sooner or later.
Ololoev
Re: IPTV
Fri Sep 09, 2016 7:13 am
I not against to wait, I perfectly understand that it is very difficult to add one or another function to the device, but the first request of users was 5 years back and it is not yet known how many will decide, I am ready to wait name exemplary terms
jarda
Re: IPTV
Fri Sep 09, 2016 10:35 am
You need to understand, that you can be asking for something for 10 years and mikrotik will not do what you want. It is their decision what to implement and what not, and if so, when it will be. Everything cost resources and they decide to do only those things that they believe will bring more money back. If you want to force them whatever more above it, you need to buy mikrotikls company to be able to give them an order they must fulfil.
Ololoev
Re: IPTV
Fri Sep 09, 2016 10:48 am
I without your advices will understand that to do
jarda
Re: IPTV
Fri Sep 09, 2016 11:53 am
Great. And please, do not quote the last message, it is obvious to what you are replying... :-)
Users browsing this forum: No registered users and 84 guests
