cylent
No web proxy in 3.0Beta1?
Mon Oct 02, 2006 11:29 pm
What happened to the web proxy in 3.0Beta 1?
heh :roll: :roll:
cmit
Tue Oct 03, 2006 12:42 am
cylent, I didn't have a chance to take a deeper look at 3.0 yet, but please keep posts about the beta versions to the beta forum - just to avoid confusion...
Best regards,
Christian Meis
normis
Tue Oct 03, 2006 9:43 am
it's in the system package now
cylent
Tue Oct 03, 2006 10:00 am
Cool!
well i cant move my own thread so...
i must say its quite nice. the look is more polished?
sandov63
Re: No web proxy in 3.0Beta1?
Fri Feb 15, 2008 3:15 pm
hi, a question for you, if it is in the system menu, why i install 3.0 stable version and i restore a backup made out of 2.9.50 version and a message showing something like '192.168.100.50 to http://www.hotmail.com cache miss'' apears ?. i restore and old configuration stored,
best regards
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
janisk
Fri Feb 15, 2008 3:53 pm
these versions does not have compatible configuration (some settings can be the same but some are different,) you have to be very careful if you want to use backup/export from 2.9 version on your 3.x installation.
Users browsing this forum: damji98, GuJack20, Kindis, stanimirhtc and 214 guests
