SystemErrorMessage
CRS switch LACP support
Thu Sep 22, 2016 8:58 am
Would like to request the 802.3ad bond type be added for the switch. Currently with another mikrotik device balance rr works fine but when using with a device that uses the 802.3ad LACP type the switch cant seem to pair up and ends up with loops despite the device itself using rstp.
fposavec
Re: CRS switch LACP support
Thu Sep 22, 2016 1:33 pm
for now you can use only static bonding
on mtik devices use xor bonding
SystemErrorMessage
Thu Sep 22, 2016 7:55 pm
Balance rr works well too with the switches but 802.3ad doesnt. 802.3ad is considered the standard in bonding.
Splash
Fri Sep 23, 2016 4:10 pm
I see that running RouterOS 6.36.3 on a CRS125 it does support 802.3ad as a bonding mode.
Did I miss understand this question?
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
SystemErrorMessage
Fri Sep 23, 2016 7:29 pm
Seems like i forgot to update my switch. I'll update and see if it works.
nz_monkey
Fri Sep 23, 2016 11:09 pm
Bonding is handled in software by the CPU
Everyone is after 802.3ad in hardware on the switch chip, and with LACP
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
SystemErrorMessage
Mon Sep 26, 2016 9:32 am
I updated to latest firmware and can confirm that bonding on switch chip for 802.3ad still isnt there in routerOS. I am trying to connect 2 ports to AC88U and on asus website says to select 802.3ad on the other device. When i attach both cables i get a few timeouts than everything works for a few minutes till the switch chip gets overwhelmed (seems like a few broadcast packets with own address overwhelms it). I thought the CRS was supposed to be wirespeed which meant the switch chip being fast enough. In other words if in an environment where you're discouraged from using NAT (like student ISPs) than the CRS is likely to always keep freezing.
My previous switch which was a netgear profsafe handled the swarm of broadcasts without going down.
manbot
Wed Oct 19, 2016 11:20 pm
And I am need LACP support in CRS-210-8G-2S for my DS1515+
Just need it!
Why? Bcoz my CCR1016 - can it!
Users browsing this forum: No registered users and 100 guests
