ariosvelez
HotSpot SplashPage
Fri Sep 23, 2016 5:43 pm
Can I have 2 HotSpot with 2 separated SplashPages for each one on one Mikrotik in this case I have a RB2011 ROS 6.36
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
MTCNA, MTCRE, MTCINE
razavim
Trainer
Trainer
Re: HotSpot SplashPage
Fri Sep 23, 2016 11:42 pm
i believe you can. as long as you will run them on different interface
Sent from my SM-N910C using Tapatalk
MikroTik Trainer
Drone Developer
Artificial Intelligence(Deep Neural Network)
2frogs
Long time Member
Long time Member
Sat Sep 24, 2016 5:48 am
Yes you can. Save your files in 2 different folders and upload them to them to the router. Under IP>hotspot>server profile change the HTML Directory on each of your profiles to the folder name that you uploaded.
ariosvelez
Mon Sep 26, 2016 3:13 pm
Thank you that was the solution you got that right as long as I have the HTML file on a different folder on file and have that selected on the profile it work perfectly.
Users browsing this forum: No registered users and 72 guests
