MUM Europe 2020
superrouter
how to block users on hotspot from seeing eachother?
Sat Oct 07, 2006 11:06 am
Hi, I have multiple rb 112 highsites connected through wds and authenticating using the hotspot sysem on a rb 500 board. My problem is that i do not know how to block users from accessing eachothers pc's on the network. Does anyone have any ideas which could help me out?
adaheem
Sun Oct 08, 2006 4:49 am
use Linksys WRT54 as an AP ,it has an isolation option.
savagedavid
Trainer
Trainer
Sun Oct 08, 2006 10:10 am
You are kidding right?
On your RB you can turn off default forwarding to stop clients on the same AP seeing each other. You can also use the firewall to block ports 135 and 443-445 to stop NETBIOS communication between PC's on different routers. Do you just want to stop users from seeing each others computers in Network Neighbourhood? This will do the trick in that case.
jo2jo
Forum Veteran
Forum Veteran
Sun Oct 08, 2006 10:39 am
adaheem is right...if you use link$y$ wrt54 ur users will have bigger problems than seeing each other, so the issue will then be "isolated".
jk, the post above this has the right answer
balimore
Forum Veteran
Forum Veteran
Sun Oct 08, 2006 10:45 am
i drunk some coffee to make more understand of MT's manuals
:lol: :lol: .....no comment...
Hasbullah.com
superrouter
no kidding ! ;)
Sun Oct 08, 2006 3:21 pm
So even if i have multiple rb ap's linking together via wds turning off default forwarding will work?
hroubaix
Mon Oct 09, 2006 12:35 pm
Please correct me if I’m wrong.
Won't you create the hidden node problem by turning Default forwarding off?
So if you have a small network, 10 - 20 users this should work ok, but for larger networks this could cause some problems in peak times.
Regarding the firewall option.
It will work to block the above mentioned ports, between routers, but not for users connected to the same AP.
I would also like to know an answer to this as I'm experiencing the same problem. I know about nstream, but it won't work for my environment.
Is pppoe an answer (point to point links)?
GWISA
Tue Oct 10, 2006 10:27 am
I fail to see how? Hidden node is purely RF/802.11 related, whereas 'default forwarding' is exactly like the Linksys 'isolation' option - just blocking access between clients connected to the same AP...
HarvSki
Tue Oct 10, 2006 4:33 pm
Yes Link$y$ wonderful choice, not ;)
Switch off default forward. Hidden node is an RF problem due to 802.11 use of CDMA which can be helped by lowering the RTS/CTS of the clients to <500 . Although this is not possible on a public hotspot
Users browsing this forum: anom3, MSN [Bot] and 106 guests
