believewireless
BGP Not Advertising other BGP Routes
Sat Oct 07, 2006 5:58 pm
We have redistribute connected, static and other BGP turned on for all routers. All routers are running Mikrotik 2.9.30 & 2.9.31. Same AS between three routers.
The middle router sees the route from one peer but isn't advertising it to the other:
/ip route print from [find gateway=6.2.52.89]
46 ADb 6.2.53.0/24 r 6.2.52.89 200 ether1
/routing bgp advertisements print 6.2.216.221
<Route isn't listed>
Any idea what is causing this behavior?
changeip
Sat Oct 07, 2006 7:06 pm
Is it an active route on the middle router?
Sam
karyal
Re: BGP Not Advertising other BGP Routes
Sat Oct 07, 2006 10:42 pm
Did you try setting nexthop-choice=force-self on the peers configuration?
Bye,
Ricky
believewireless
Sun Oct 08, 2006 8:25 am
force-self is on every peer. We have the following:
ISP1 -> MT 1 -> MT 2 -> MT3 -> ISP2
We are trying to get the route on MT1 to be announced by MT3 to ISP2. It's in /routing bgp network on MT1 and seen by MT2 but not announced to MT3.
All filters have been removed and it's still not being seen. Any ideas?
changeip
Mon Oct 09, 2006 1:12 am
Sam
repeat ... is it an active route on the middle router?
Sam
believewireless
Mon Oct 09, 2006 2:34 am
Yes, I already showed that in the first post:
Eugene
Forum Veteran
Forum Veteran
Fri Oct 13, 2006 4:21 pm
issue /routing bgp peer resend-all command and see if the route is being advertised afterwards. If it is not, send support output file to support@mikrotik.com
Eugene
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
believewireless
Sat Oct 14, 2006 1:56 am
It looks like the resend fixed it. Thanks.
I did notice a route today where that didn't fix it. I had to disable the peer and re-enable it for it to work.
Eugene
Forum Veteran
Forum Veteran
Fri Oct 20, 2006 2:07 pm
You have to report such cases accompanied by support-output files to support@mikrotik.com
Eugene
Users browsing this forum: brwainer, eworm, kos, naudkuneha, ysha and 70 guests
