MUM Europe 2020
savagedavid
Trainer
Trainer
Serious problem with static routing in 2.9.31
Sun Oct 08, 2006 2:39 am
Since upgrading my main router to 2.9.31 I am experience a serious issue. A ny new route I add through my outgoing (ether) interface appears with interface as unknown, even though the IP is valid and I can ping the gateway. As well as that, some of my current policy routing rules have also gone the same way. Even if I remove and re-add the current default gateway it appears as invalid and all internet access shuts down. The only way I can get it back is using the undo command.
This is very scary as I feel my router is in a very unstable condition. I dont want to downgrade either for fears it might carry the problems through to the previous version.
I have sent a supout.rif to support[at]mikrotik.com already.
changeip
Mon Oct 09, 2006 1:13 am
I think this is the issue posted elsewhere this week. Seems winbox is adding routes with the wrong target-scope - scope settings I believe. Check using CLI.
Sad that QA didn't catch that, and the common way of adding routes (using winbox) wasn't tested.
Sam
sergejs
Mon Oct 09, 2006 8:25 am
savagedavid, it will be fixed in the new version.
savagedavid
Trainer
Trainer
Mon Oct 09, 2006 3:34 pm
So will using CLI to add the routes instead fix the problem? Note that it was some of my existing routes that stopped working as well as new routes that I added.
dfwair
Mon Oct 09, 2006 6:14 pm
I ran into this and posted it last week. The conversation contained nothing of value, but here it is:
http://forum.mikrotik.com//viewtopic.php?t=11241
savagedavid
Trainer
Trainer
Tue Oct 10, 2006 8:36 am
OK so this is what I found. To get it working I had to delete all invalid routes and policy routes in the route table, then re-add the exact same routes but via command line. This seems to work as a temporary solution.
chris-oct
Thu Oct 12, 2006 6:59 pm
Unfortunately it appears they did not fix it in 2.9.32 :(
I am hoping they did fix it and just forgot to add it to the changelog...
Changelog for 2.9.32:
*) fixed bug in PPPoE, PPTP and L2TP - rate limiting queue addition failed sometimes;
*) fixed bug in PPPoE, PPTP and L2TP - after reboot 100s of users reconnecting can make
some connections non working;
*) fixed bug in PPPoE, PPTP and L2TP - some logged out users could still be shown in active
ppp users lists, disallowing re-login if only-one is set;
*) speed up WinBox secure mode data transfer rate 2.5 times;
*) notice clock changes made by NTP and adjust GMT offset accordingly;
*) console command "system reset" has been renamed to "system reset-configuration";
*) user manager - improved object removal performance;
*) user manager - added session and log removal;
*) user manager - user page now requires customer's public-id;
*) user manager - fixed logout crash bug;
*) user manager - fixed order of dirs in export;
dfwair
Thu Oct 12, 2006 8:16 pm
I just put it on a test box and it does appear to be working correctly, just didn't make it into the changelog.
savagedavid
Trainer
Trainer
Fri Oct 13, 2006 11:57 am
Thanks I will try it out today and post feedback
BrianHiggins
Long time Member
Long time Member
Sat Oct 14, 2006 10:20 am
http://forum.mikrotik.com/viewtopic.php?t=9520
savagedavid
Trainer
Trainer
Sun Oct 15, 2006 12:26 am
Initial tests seem to indicate it is now working correctly. I will post any further updates if required.
Users browsing this forum: dairou, Gallego, mbovenka, mrmut, xiaotuzi and 149 guests
